RV.Net Open Roads Forum: Class C Motorhomes: No power from house batterys
 > No power from house batterys
pauly boy
canada
Posted: 05/16/23 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
I'm fine with shore power but I don't seem to be getting any power from the house battery's(2). Was working. Any idea's.
Thanks Paul
corvettekent
Marysville, WA
Posted: 05/16/23 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Check the voltage at the house batteries. Is the battery switch turned on?
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
bobndot
Posted: 05/16/23 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
If the switch is on then i would ,
Remove the cables to the battery and check the voltage. 12.6 - 12.8 range would be a fully charged battery.
If there is no 12v power once you replace the cables, i would check the fuses and make sure the ground connection off the neg battery terminal to the chassis ground is clean.
pauly boy
canada
Posted: 05/17/23 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you gentlemen . I'll try both. Fingers crossed!
cencerrita
Posted: 05/18/23 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Paul
Do you have a generator and is that supplying house power.
www.cencerrita.comNow living in Pembrokeshire, Wales, UK. See our web site for US travels and books www.cencerrita.com
bobndot
Posted: 05/18/23 11:54am Link  |  Quote  |  Print  |  Notify Moderator
This post has 2 pages of info and pics on p2. It may be helpful.
https://heartlandowners.org/threads/solv........hen-disconnected-from-shore-power.59714/
pauly boy
canada
Posted: 05/23/23 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Problem solved. Motoring west next week. Ya Who
way2roll
Wilmington NC
Posted: 05/23/23 07:41am Link  |  Quote  |  Print  |  Notify Moderator
What was the solution? Reporting back can help others.
2023 FR Sunseeker 2400B MBS
VA-Apraisr
glen allen, VA
Posted: 05/23/23 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
x 2!!! This website helps everyone by posting a problem/situation and FINDING A SOLUTION!
bobndot
Posted: 05/23/23 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Hey what is this, the RV Net version of ‘I’ve Got A Secret ? ??
