RV.Net Open Roads Forum: Tech Issues: 30 amp camper/50 amp plug and cord
 > 30 amp camper/50 amp plug and cord
Terry 25
Hagerstown, MD
Posted: 05/16/23 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Just bought a Puma 25BHFQ. One A/C and a 30 amp camper in every way but the plug and cord are 50 amp. Must I always use an adapter or can I plug into 50 amp if available? Thanks. The camper is on a permanent site with a 30 amp plug. I'd like to eliminate the adapter by installing a 50 amp plug.
2016 F-250 Gas
2015 Rockwood 2608WS
Cummins12V98
on the road
Posted: 05/16/23 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
You should be able to plug your 50A cord into a 50A receptacle.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cptnvideo
Arizona - most of the time
Posted: 05/16/23 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
I would check the RV breaker panel first. If you have a 2 pole main breaker, then you can plug directly into a 50 amp outlet.
But if you have a single pole main breaker, then where is the 2nd hot wire going?
I assume you know a 50 amp outlet is actually 2 50 amp hot wires, a neutral and a ground.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
valhalla360
No paticular place.
Posted: 05/16/23 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds goofy, so be careful of internet advice. Not that the folks aren't knowledgeable but you may be feeding them confusing information.
Best bet would be to get someone local who is good with electrical to look over your system. It makes no sense that you would have a 240v/50amp inlet feeding a 120v/30amp system...it can be done but makes no sense, so it makes you wonder if someone home brewed the change and if they knew what they were doing when they did it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
fj12ryder
Platte City, MO
Posted: 05/16/23 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
You say it's a 30 amp camper, but has a 50 amp cord and plug. Is the outlet where the cord plugs into the camper 50 amp? IOW is the plug that goes to the camper a 50 amp plug? 3 prongs and a ground?
Howard and Peggy
"Don't Panic"
BB_TX
McKinney, Texas
Posted: 05/16/23 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
A picture of your cord (both ends) and your RV connector would take all the guesswork out of anyone here trying to help.
JimR 1
Custer South Dakota
Posted: 05/16/23 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I remember a post like this a while back a 30 amp camper with a 50 amp Cord. The post was in April.
JimR
Bobbo
Wherever I park
Posted: 05/16/23 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
JimR
Actually, that case had a 50 amp camper with a 50 amp cord, BUT, the wrong sticker was placed by the camper's power inlet. The sticker that was applied said it was a 30 amp 125v camper. On further inspection, that camper had a ganged 50 amp main breaker. Here is that (12 page) thread: 30 vs 50 amp electrical issue help
Bobbo and Lin
C Schomer
Pueblo West, Co.
Posted: 05/16/23 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Id put the right cord on it and plug it into the right receptacle with the right over currant protection. Craig
AllegroD
Outdare
Posted: 05/16/23 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
I would post a pic of your CB panel, as well.
