RV.Net Open Roads Forum: Better/brighter interior bulbs?
 > Better/brighter interior bulbs?
Almot
out there
Posted: 05/16/23 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Long time ago replaced interior incandescent bulbs with SMD LED boards with 10mm wedge base, ~20W equivalent, ~320 lumens. Was happy, now want something brighter but can't find anything more powerful in this form-factor. Here is a typical offer, scroll down to specs with 24 LED: board 4.4 cm diameter, 370 lumens: ">IoAAOSwRxtZxMGA]24-5050 SMD
Double pancake dome light would probably accommodate a larger diameter board, but I can't find any. Don't want to overpay for a whole new fixture when just the "bulb" needs replacement. Or should I give up the idea of a wedge base fixed rigidly to the SMD, and look for a rectangular board like 48-5050, with wedge base dangling on the wire. Can such a board be drilled through, to attach it to the dome fixture, did anybody try?
I prefer a board, not a "cob", because a cob would have 30-40% of LED diodes illuminating the ceiling behind them. Any suggestions are welcome.
PS: would be nice to find a source with proven quality. Ebay is huge same as the China itself and full of cr-ap, with some more reliable sellers like the one in the link.
* This post was edited 05/16/23 07:47pm by Almot *
StirCrazy
Kamloops, BC, Canada
Posted: 05/17/23 07:04am Link  |  Quote  |  Print  |  Notify Moderator
use double sided tape to attach it to the fixture base.
* This post was edited 05/17/23 07:49am by an administrator/moderator *
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
profdant139
Posted: 05/17/23 10:08am Link  |  Quote  |  Print  |  Notify Moderator
We've had great luck with m4 -- they are located in the US and they answer questions quickly and correctly. More expensive than "straight outta China," but much more reliable and trustworthy:
m4 LEDs
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Almot
out there
Posted: 05/18/23 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, people. m4 LEDs is a nice store, I like how they grouped and specced everything there, no guesswork. Double sided tape should work, yes.
With trailer being that small and with low ceiling I think I will upgrade different "pancakes" in a different way, in some will put more powerful square SMD boards and some would be nice to replace with flat panels like this one: Dimmable 1800 lumens 12" panel. Dimmable and changeable color temp, imagine that.
C Schomer
Pueblo West, Co.
Posted: 05/20/23 04:15am Link  |  Quote  |  Print  |  Notify Moderator
Superbrightled.com is also good. I recently read that 5050 leds are old tech and 2835s are brighter. FWIW, I gutted my 3 ceiling fluorescents and used hi density led tape with a hot-wire dimmer. The tape is, total, 5k lumens and 5k color. There's no shortage of light anymore and my old eyes need the bright white.
You might need a different fixture to get the lumens you want.
I also just bought a double sided under counter light, 4500k color and 750 lumen for $12.
I've had good luck with Amazon but led shopping is very brain damaging and it takes time to cipher different mfgrs. specs! Craig
Almot
out there
Posted: 05/20/23 08:58am Link  |  Quote  |  Print  |  Notify Moderator
C Schomer, LED shopping is VERY time consuming. Most sellers don't bother with full specs, some quote watts or a number of diodes instead of lumens. Some LED come in different wattage like 2835. It can be either brighter than 5050 or dimmer, depending on wattage.
Incidentally I am looking for a complete under-cabinet fixture too, ~1000-1200 lumens spread over 2-3 ft length, preferably with matte lens to avoid casting shadows in pots and pans. With a switch on the fixture so that I won't have to look for a remote. My current light is 700 lumens double dome, I could add another dome but this is inconvenient, 2 switches. Amazon has interconnecting 300 lumens 1ft panels but interconnects are cables, not rigid end-to-end connectors, and switch is in-line on cable. Can you give a link to your under counter light?
msmith1.wa
Tacoma, WA
Posted: 05/21/23 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
I installed two of these above the table in my toy hauler.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
C Schomer
Pueblo West, Co.
Posted: 05/28/23 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I was also looking for a 5k temp, 3 foot LED under counter fixture but they are very rare so I ended up with the double sided 5k/750 lm fixture. My range hood is nothing but a head basher and I have a max fan right above the stove that works 100 times better than the range fan ever thought about so I’m removing the hood and putting in a light instead. I wanted a long light bar to span the hood and the adjacent single light, but I will just put up with two switches. Craig.
Almot
out there
Posted: 05/28/23 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
C Schomer, I hear you about head basher hood.
For under cabinet (not under counter) I found 20" bar 20"x1.5" 8W, "should be" ~1,000 lumens, now need to choose btw this or this 20"x6.5" 1400 lumens. The latter is much pricier but also much wider, good to illuminate the counter from low height.
Edit: corrected typo - it's 8W LED bar, not 8A of course.
* This post was edited 05/28/23 11:54pm by Almot *
StirCrazy
Posted: 05/28/23 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
in my camper, I got rid of the old 1991 brake light fixtures and installed these nice color temp and 0.3 amps per working side. so, the doubles you could be pulling 0.6watts if both sides are on. The old fixtures with big bulbs would pull 1.5 amps and while the color temperature was close they were half as bright.
