I purchased these back in 2021.
I had replaced my OEM incandescent bulbs that came with the 5er - in 2010 and it was a huge upgrade; However, they weren't very bright.
I did some research and ended up with the ones linked below. They are much brighter (Lumen output) don't put out much heat and have held up well for the last couple of years (no failures at all - running on Generator as well as battery).
Because my original replacement LED's were double sided taped into the fixture, I left the old ones in the fixtures and put the new ones in. Last month I was was cleaning out the gnats from the light fixtures and connected the one of the old bulbs and the new one and the output of the Lumens was staggering. I've forgotten just how much brighter the new ones are compared to the old ones.
Oh, one more thing. The ones I picked were more yellow than blue in color blue (warm white). When I clicked on the original link, I needed to select Warm White - or you'll get the 6000k ones.
Wow. 1000 lumens per 1.5" board is really bright. 2000 lumens per fixture could be more than I need, but at $1 per board might as well try it. Thanks joedeb720.
Almot wrote: Wow. 1000 lumens per 1.5" board is really bright. 2000 lumens per fixture could be more than I need, but at $1 per board might as well try it. Thanks joedeb720.
I would be skeptical of the Lumen rating as a 40 watt incandescent bulb is not 1000 Lumen in fact the average 40 wat bulb is less than half that. it takes up to a 70 watt bulb to hit the 1000 lumen range
