Paul.Guenther
New Braunfels, Texas
My passenger side headlight only works on high beam on my 2002 Tiffin Zephyr. Driver's side works fine. Have replaced the bulb. Any suggestions will be appreciated!
CA Traveler
The Western States
Assuming the new bulb is OK then it's most likely a wiring connection between the two bulbs,
2014 Grand Cherokee Overland
Bob
I oncce had a connector with a bent pin.. It did not go into the socket properly. Straightened it and all good.
