RV.Net Open Roads Forum: Towing: Will Air bags make a big difference?
Search only in Towing
Open Roads Forum  >  Towing
 > Will Air bags make a big difference?
Page of 8
GaryS1953
Michigan
Posted: 05/26/23 06:35am Link  |  Quote  |  Print  |  Notify Moderator
To Grit dog, By the way, forgot to mention that the previous owner had flipped the axle on this trailer. Not sure why. Seems to me with adjustable hitches it really only makes sense to do it on 5th wheels, not TTs. In any case, could that be contributing to our issues?
Gary in Michigan
2014 Chevy Silverado 1500 Double Cab 5.3 Liter V8
1996 Coachmen Catalina RB210 21' Fifth Wheel
495 Watts Solar, 40 AMP Renogy Tracer MPPT Controller,2 GC2 6V Batts.
JRscooby
Indepmo
Posted: 05/26/23 07:04am Link  |  Quote  |  Print  |  Notify Moderator
That can really make a difference in the way a trailer handles. If done right, raising COG is never a good thing. Add the fact it would be hard to be sure it was done right.
opnspaces
San Diego Ca
Posted: 05/26/23 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Hi Gary, when you say your tires have a max load of 35 PSI where are you getting that number? Is that on the sticker on the drivers door jamb or on the tire itself? The tires should have a max pressure of 45PSI cold embossed directly on the sidewall of the tire.
I would at least put the rear truck tires at max cold (max cold is first thing in the morning before you drive more than a few blocks) But as Grit says if the 45 is still not right you can try 65 PSI and drive it for a few miles for a test.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
valhalla360
No paticular place.
Posted: 05/26/23 09:56am Link  |  Quote  |  Print  |  Notify Moderator
What is the weight rating on the side of the tire? If 35psi is the max pressure, the tires may have a lower rating than the rear axle. Soft squishy car tires may be fine running around empty but overload them and the ride can get squirrely and you risk a blowout.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
wnjj
Cornelius, Oregon
Posted: 05/26/23 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Flipping TT axles helps with ground clearance. The previous owner may have had a parking space with a steep angled driveway to back into.
GaryS1953
Michigan
Posted: 05/26/23 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Oh boy, now I'm feeling REALLY stupid. I could swear I saw it on the tire, 35 max PSI, but you are right, it says 44 PSI. I will be airing them up shortly.
Posted: 05/26/23 11:51am Link  |  Quote  |  Print  |  Notify Moderator
44 will help. Try 55 to see how stout tires feel. You still have marginal at best tires.
Flipped axles shouldn’t matter at all except a little higher center of gravity. Won’t make it buck more.
GaryS1953
Michigan
Posted: 05/26/23 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Ok for those still following this thread and offering advice - I went back to the Cat scale, hope I've got this right.
1st ticket -Steer Axle only 5,780 The truck on only one pad.
2nd ticket Steer Axle 3,260
Drive Axle 3,460
Trailer Axle 5,940
Combination 12,660
So I added the two truck axle weights, then subtracted the truck weight, and I get a difference of 940, divide by the truck actual weight of 5780, and I get 16.26% Am I doing that right?
Also, I overinflated the truck tires to 55 psi, and it seemed to help with small bumps, but large bumps still cause what I call bucking, where the front and back of the truck jump up and down, and I still feel like the truck is too light in front and it seems difficult to keep the truck going straight down the road. Next thing I guess I'll probably try is adding leaf spring helpers as Grit dog suggested. Any particular type recommended? Not exactly sure what I'm looking for.
Finally I borrowed a 3/4 ton Chevy Duramax and towed the camper with that. Still, some very minor bucking, but it was like night and day, and, perhaps even more importantly, I could steer with one hand, it was that stable in the front.
valhalla360
No paticular place.
Posted: 05/26/23 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Drive Axle 3,460
Trailer Axle 5,940
Combination 12,660
Technically wrong but decipherable. 1st Ticket should have had the truck axles on separate pads but close enough we can figure things out:
- Truck goes from 5,780 to 6,720 (3260+3460), so the hitch weight is 940lb as you calculated.
- Trailer weight is 5,940 + 940 = 7,880lb. (within the trailers 9,462GVWR)
- Hitch percentage is 940lb/7,880lb = 12% (OK range)
I'm betting the 35psi is causing a lot of the issue. What was the weight rating off the side of the truck tires? At 45psi, it might be OK.
wnjj
Cornelius, Oregon
Posted: 05/26/23 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Drive Axle 3,460
Trailer Axle 5,940
Combination 12,660
If you are trying to calculate the percentage of tongue weight, you should divide by the trailer's total weight. So 940/(12660-5780) is about 13.7%. Still good though.
Page of 8
