RV.Net Open Roads Forum: How common are fold-up vs "standard" sinks in wet baths?
 > How common are fold-up vs "standard" sinks in wet baths?
coolusername
Posted: 05/21/23 12:44am Link  |  Quote  |  Print  |  Notify Moderator
Exactly what the title asks: in RVs, what type of sink is more typical or common, or which would I be more likely to find: fold-up sinks, or "standard" sinks with the basin fully built into/attached to the wall or some other surface? I'm particularly thinking of wet baths here, especially since I assume those are probably more variable in sink styles and amenities compared to the "normal" setup in dry baths. (As for RV size/type, if that's an important factor in answering, probably consider a Class C on the larger side.)
And even just in general, how common actually ARE fold-up sinks (I feel like, relatively speaking, I don't really see or hear about them all that much, even in wet baths)? Are they considered particularly typical for RVs/wet baths at all or are they more of a "special case" sort of feature?
austinjenna
Columbus, Ohio
Posted: 05/21/23 04:50am Link  |  Quote  |  Print  |  Notify Moderator
From my experience the fold up sink is typically in a class B or truck camper because the majority of those rv's have wet baths, Generally a class C as you mentioned has a dry bath and would have a fixed sink.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
fj12ryder
Platte City, MO
Posted: 05/21/23 06:55am Link  |  Quote  |  Print  |  Notify Moderator
I think a foldup sink would be most common in the low-wall popup campers. TBH I've not seen one in years.
Howard and Peggy
"Don't Panic"
Reisender
NA
Posted: 05/21/23 07:15am Link  |  Quote  |  Print  |  Notify Moderator
We have one in our T@B400. Works well.
coolusername
Posted: 05/21/23 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
I’m not super versed in the common differences between them, but what about motorhomes rather than towed campers? Do the self-propelled “vehicle” RVs (motorhomes and the like, not sure if there’s other terms for them) not usually have fold-ups for bathroom sinks compared to smaller, towed camper spaces?
fj12ryder
Platte City, MO
Posted: 05/21/23 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
I honestly can't say that I've ever seen one in a modern motorhome. Maybe in the little ones, with fewer frills, but IMO they send the "cheap" message.
coolusername
Posted: 05/21/23 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
That’s true, I have noticed most Class Cs tend to have a dry bath, although there are some that still have wet baths right? I know I’ve seen a few. In an RV with the general size/style of a Class C—for those that do have a wet bath—would they still be more likely to usually have a sink fixed to the wall or other surface even if it’s in a wet bath?
* This post was edited 05/21/23 09:20pm by coolusername *
