RV.Net Open Roads Forum: Tech Issues: Connecting 2 batteries together
 > Connecting 2 batteries together
swimmer_spe
Sudbury, Ontario, Canada
Posted: 05/21/23 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have space for 2 batteries where I currently have one. The one I will be adding is identical, except it is about a year older. Am I right, I need to daisy chain them?
Dutch_12078
Winters south, summers north
Posted: 05/21/23 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
No... Two 12-volt batteries must be connected in parallel to still supply 12 volts, but at twice the amp/hours. "Daisy chained" would supply 24 volts, possibly burning out most of your 12 volt devices.
Dutch
2001 GBM Landau 34' Class A
agesilaus
North Florida
Posted: 05/21/23 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Battery wiring
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
Posted: 05/21/23 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Well in electrical terminology for daisy chain in residential IS parallel connections.
But potato pototo.
Yes parallel them. Not series.
bob213
Fresno, CA
Posted: 05/21/23 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure about pairing batteries of different age but here's a great guide on how to do it correctly...12v side of life
12v
Posted: 05/22/23 04:27am Link  |  Quote  |  Print  |  Notify Moderator
There are a lot of myths about paralleling batteries.
For the most part the only thing you need to concern
The Connecting cables need to be large enough (Same as the cable that runs off to who knows where)
And the polarity.
Most everythign else the batteries will work out by themselves
In some very high current installs there is more (Load Balance) But you are into the hundreds of amp loads before that's a concern.
With GC-2's there are additional concerns but since you are not going that route. That is all folks.
Bobbo
Wherever I park
Posted: 05/22/23 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Hook the two POSITIVE terminals together. Hook the two NEGATIVE terminals together. For best results, hook the trailer's POSITIVE cable to the POSITIVE terminal of one of the batteries, and the trailer's NEGATIVE cable to the NEGATIVE terminal of the other battery.
Bobbo and Lin
Posted: 05/22/23 09:26am Link  |  Quote  |  Print  |  Notify Moderator
THANK you. Lol
Posted: 05/22/23 09:29am Link  |  Quote  |  Print  |  Notify Moderator
And the polarity.
Not sure of the myths…but for sure there are some guidelines.
Wondering what the addl concerns might be with 6V batteries though? You said there are concerns?
Aside from having to hook up in series or series-parallel I’m not aware of any “concerns.”
pianotuna
Regina, SK, Canada
Posted: 05/22/23 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe
This is what is balanced and best for twin twelve volt batteries.
As it often doesn't cost a dime more to do this, I think it is worth the trouble.
If you wish to understand the "why" surf here:
correctly interconnecting multiple twelve volt batteries
Others may say it doesn't matter--but unless there is a compelling reason to not optimize charging and discharging why not do it the best possible way?
Regards, Don
