swimmer_spe
Sudbury, Ontario, Canada
I know if you overfill your fresh water tank, generally, there is an overflow and it dumps on the ground. What about your grey and black? Does it just start to come out of those things that drain there?
Dutch_12078
Winters south, summers north
swimmer_spe wrote: I know if you overfill your fresh water tank, generally, there is an overflow and it dumps on the ground. What about your grey and black? Does it just start to come out of those things that drain there?
Yes... The grey tank will typically back up into the shower or tub, and the full black tank will not allow anything to flush and may back up the vent pipe making for a nasty surprise when the toilet flush valve is opened.
Dutch
2001 GBM Landau 34' Class A
rk911
DuPage County
yup, usually at the lowest point which is the shower. In our first MH the shower was plumbed into the black tank.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
rk911 wrote: swimmer_spe wrote: I know if you overfill your fresh water tank, generally, there is an overflow and it dumps on the ground. What about your grey and black? Does it just start to come out of those things that drain there?
Uuuuurp!
Goostoff
Wisconsin
SHITTER"S FULL!!!!!!
1993 Chevy C3500
2005 Cedar Creek 34RLTS
You’ve had campers-how long? Do these questions just pop into your head randomly and keep you from getting good sleep or??
And what are “those things that drain there?”
ScottG
Bothell Wa.
And sometimes the tanks distort and fall out of the rig.
Boomerweps
Hills of PA
The FW tank has an overflow at the top that may (should) feed a hose to a screened vent.
The GW & BW tanks have large vent pipes that extrude through the RV roof, to try to avoid any smells. They will back up through the drains if overfilled or be easily visible in the large toilet ball valve.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
2112
My gray tank is full when the shower no longer drains.
My black tank is full when the toilet burps when I flush.
My gray fills up long before the black. I put a valve on the main drain pipe where you connect the drain hose. With that valve closed I open the gray valve, wait a few second, then open the black valve to move some gray water to the black tank. Then close both valves. That gets me at least another shower before to the dump we go.
2013 KZ Durango 2857
Itinerant1
Itinerant
As mentioned when the black tank is getting near full it will burp when you flush.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,400+ partial cycles.
