RV.Net Open Roads Forum: Is it better to be hooked to short power in storage? or not?
 > Is it better to be hooked to short power in storage? or not?
trailernovice
Mission TX
Posted: 05/22/23 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
I just found a storage place that not only has covered storage (metal roof/exposed sides), but it also has 30 and 50 amp shore power.
In the past, I've had our TT stored in the open with no connections
Better to have it connected to shore power when stored between uses/trips? or better to have everything (including the battery) disconnected?
Thanks for your thoughts
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
BB_TX
McKinney, Texas
Posted: 05/22/23 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
My 5er alway plugged into 20 amp power any time in covered storage to keep battery charged. And to have power if I needed to do any kind of work or cleaning.
pianotuna
Regina, SK, Canada
Posted: 05/22/23 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
It depends.
Regards, Don
phil-t
Ogdensburg, NY
Posted: 05/23/23 12:53am Link  |  Quote  |  Print  |  Notify Moderator
I like mine connected, while in storage, mainly to keep batteries up; though I have managed a couple months of non-use by disconnecting batteries.
2014 Allegro 36LA
mkirsch
Rochester, NY
Posted: 05/23/23 04:56am Link  |  Quote  |  Print  |  Notify Moderator
Summer storage? Keeping it charged and ready for trips? Using it more than once or twice a year? Plug it in.
Winter storage? Using the camper only once or twice a year? Take the battery home and put it somewhere cool and dry, on a maintainer. Don't pay the storage facilities' inflated power charge.
Tvov
CT
Posted: 05/23/23 04:57am Link  |  Quote  |  Print  |  Notify Moderator
I disconnect and shut everything down between trips, unless it will only be a week or two before the next trip. I disconnect the battery when not using the TT. I usually reconnect shore power about 3 days before a trip, and that is enough to get the battery charged up and the frig cooled down and filled up.
I know people who leave everything hooked up all the time, and it works fine for them.
I think it is whatever you want to do.
2021 F150 2.7
wildtoad
Blythewood, SC
Posted: 05/23/23 04:59am Link  |  Quote  |  Print  |  Notify Moderator
Don’t use a storage facility as I built a nice carport for it and our two cars. It stays plugged in when not in use. I keep the fridge on, AC on to control humidity and of course to keep batteries charged.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Lantley
Ellicott City, Maryland
Posted: 05/23/23 05:02am Link  |  Quote  |  Print  |  Notify Moderator
I have kept my RV's plugged in 24/7/365 for 20 plus years with no ill efects
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
midnightsadie
ohio
Posted: 05/23/23 06:25am Link  |  Quote  |  Print  |  Notify Moderator
don,t think it maters to the rv but you must maint your batteries or they will die a short life.
StirCrazy
Kamloops, BC, Canada
Posted: 05/23/23 08:10am Link  |  Quote  |  Print  |  Notify Moderator
depends on the stock converter in it and the batteries. with my 6V batteries and upgraded converter I leave mine plugged in whenever I am not camping, and I check the water level in the batteries 4 times a year to make sure nothing is going wrong.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
