RV.Net Open Roads Forum: General RVing Issues: Would You Caulk This Shower Tub?
 > Would You Caulk This Shower Tub?
wnjj
Cornelius, Oregon
Posted: 05/23/23 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
Dallas Steve said: " That and when I try to unhook it the hitch won't let go until I have raised up the back bumper of the truck a few inches. Is that normal?"
Yes, that is normal, especially with new trailer coupler, and new ball. A lube will help. I've always used a Teflon based trailer ball lube on all my trailers. It is less greasy, but super slick, and lasts longer. I put a little on the under side of coupler, and light coat on the ball.
Like all things that fit tight, it will wear in with use.
Have a good evening,
Jerry
What Jerry said plus if you are in even a slight turn when you finish backing in the ball is more difficult to separate. Another thing I find helps is to chock the trailer then put the truck in neutral and let off the brakes for a second to reduce the fore-aft pressure. If you’re on a slope use just a second of drive or reverse (with no gas) instead as needed.
DallasSteve
Posted: 05/24/23 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
I'll try to remember those tips. I think one time I did give it a slight move forward or back to help it separate. I'll try to keep the truck as straight as I can when I am ready to unhook.
2022 JAYCO JAY FLIGHT SLX 8 324BDS
2022 FORD F-250 XL CREW CAB 4X4
All my exes live in Texas, that's why I live in an RV
poppa
Dallas, TX
Posted: 05/25/23 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Second Chance wrote:
I would not - and here's the reason. The lip at the bottom of the shower surround indicates that it overlaps an outer lip on the bottom portion. This allows any condensation between the liner and whatever surface it's mounted on to drain out. Sealing it would seal in any moisture that's there. If it had been sealed when constructed and perfectly dry, that would be another thing - but not now after use. Other's may have differing opinions.
Rob
probably a leak on you drain or shower hose in the wall
