RV.Net Open Roads Forum: Tech Issues: Generac shutdown issues, help!
 > Generac shutdown issues, help!
CA Traveler
The Western States
Posted: 05/24/23 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
I was wondering about air flow. Recommend 2 or 3 of the large fans on one end, no other openings on that end. large single opening on the other end and no fans. Exhaust straight up through the top and Gen-Turi to cool it.
Also have you weighed the trailer? Looks like a lot of weight on the hitch.
2014 Grand Cherokee Overland
Bob
Posted: 05/24/23 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
Roflmao! Just stop…
It’s not a RV so not subject to all the weird travel trailer “stuff” that virtually no one else cares about…ever, when actually using trailers.
Maybe we need the payload capacity of the tow vehicle before we can talk aboot his generator too?
Posted: 05/24/23 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
You can open up the box and I think (Read the manual to be sure) Tapping the OFF button will make the last stored CODES blink out.
rjstractor
Maple Valley, WA
Posted: 05/24/23 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
For the recent respondents here asking, the OP said in his first post it runs fine without the enclosure….
Sure enough, might help if I could read a little better. [emoticon] Time to get a quieter generator or put up with the noise.
MrWizard
Traveling
Posted: 05/25/23 12:59am Link  |  Quote  |  Print  |  Notify Moderator
The fans are wrong, blow cool air in low, remove heat up high, you are pulling the cooling air flow down under the generator and out, trapping Heat inside, also the exhaust going down is just going to rise, some of it will even get pulled back into the covering box, optimal airflow is not being met with your current design, the carburetor might be too warm, causing a vapor lock, or the generator Head getting to hot and causing the engine shut down, sound reducing boxes can work when the correct design is implemented, sound mat is a good material , foam is not, egg crate or pin cushion foam reduces air flow and holds heat, many food vendors use inverter style generators on their trailers instead of open frame generators, inverter style are enclosed are quieter when running at lessor loads, if Honda or Yamaha is outside of your budget , champion and harbor freight have inverter models that are less expensive, you obviously need electrical power so it might be wise to look into replacing the generator , if not feasible, then redesign your box put the air intake in the bottom of the box with a fan blowing in, put exhaust fans on each end of the box , this will remove more heat than a single exhaust fan mounted too low trying to pull air thru and around the generator
* This post was last edited 05/25/23 01:19am by MrWizard *   View edit history
I can explain it to you.
But I Can Not understand it for you !
Connected using T-Mobile Home internet and Visible Phone service
1997 F53 Bounder 36s
CA Traveler
The Western States
Posted: 05/25/23 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Yes tow vehicle information is also needed. Weight can be a very significant factor for liability, severe accidents do happen. I wouldn't ignore it but to each his own...
joebedford
Home for the summer.
Posted: 05/25/23 08:01am Link  |  Quote  |  Print  |  Notify Moderator
I don't know how you can talk about that without knowing what kind of tires he has on his trailer.
Incidentally, I left my RV in Florida (we shall see if that's a mistake next November) and brought my "stuff" (two motorcycles, etc) home in a 16' cargo trailer. About 30km from home I noticed that the tread on one tire is "wowing" about an inch in one section of the circumference. I changed it on the spot (Walmart) but I left the other tire with wires sticking out of the tread/sidewall until I got home. I guess I'll take the opportunity to upgrade from "C" rating to "D" rating.
Oh yes, the built in Onan in my RV quits after about 20 minutes. Heat?
ScottG
Bothell Wa.
Posted: 05/25/23 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Roflmao! Just stop…
For sure a dually would solve all his problems.. [emoticon]
ScottG
Bothell Wa.
Posted: 05/25/23 08:54am Link  |  Quote  |  Print  |  Notify Moderator
IMHO those fans aren't even close to enough to moving enough air. If you really want some kind of fan, get a 14+" electric pusher fan (the biggest that will fit) for a vehicle radiator.
way2roll
Wilmington NC
Posted: 05/25/23 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Why is tow and weight information needed for this conversation?
2023 FR Sunseeker 2400B MBS
