RV.Net Open Roads Forum: Technology Corner: Should be simple WiFi question, but???
 > Should be simple WiFi question, but???
DD716TED
Washington State
Posted: 05/23/23 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
My home Xfinity router outputs both a 2.4 ghz band and a 5 ghz band... I am trying to use an app on my Samsung A7 tablet that strictly requires the 2.4 band. When I look at settings / connections, it only shows the name of the WiFi network in use BUT not whether it is the 2.5 or 5 ghz which both have the same name.. Any ideas on how to determine which one the Tablet is using? Thanks in advance for any help..
wnjj
Cornelius, Oregon
Posted: 05/23/23 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
The best method may be to rename the 2 networks so you can identify them easier:
https://www.xfinity.com/support/articles/wifi-change-admin-tool
Their example shows network 1 & 2 for the 5 and 2.4G.
fj12ryder
Platte City, MO
Posted: 05/23/23 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
My thought would be to check the router and see what channel the tablet is using, and adjust accordingly.
Howard and Peggy
"Don't Panic"
wildtoad
Blythewood, SC
Posted: 05/23/23 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
If it’s like my router, if they bands are named the same, the router will auto select which one to connect to. What the criteria is I have no clue. On mine I named them Name-2, Name-5. Then when I want to connect I’m presented with a choice.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
stickdog
Somewhere, USA
Posted: 05/23/23 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
I just a retired carpenter but what I understand if your tablet does have 5G your not going to get it.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
AllegroD
Outdare
Posted: 05/23/23 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Didn't you answer your own question? The router admin page will tell you what is connected to what but if the tablet only uses 2.4, there is your answer.
joebedford
Home for the summer.
Posted: 05/23/23 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Not 5G - 5 gHz. Not the same thing.
fj12ryder
Platte City, MO
Posted: 05/23/23 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
You should be able to select which frequency you want to use in the router settings. I know mine works that way, I can select either 2.4 or 5.
Posted: 05/24/23 04:30am Link  |  Quote  |  Print  |  Notify Moderator
Get a new router I had that kind of router(One SSID two bands) and several devices refused to connect to it
My New TP-Link Archer-10 has 3 SSIDs two are the same ..almost.. I set them to the 2.4 GHz SSID to the same as the old router (Saves logging in all the old hardware) likewise the PSK I set the same.. The 5 GHZ band is the same save for the addition of 5GHz to the ssid..making both of the bands Unique The Third SSID (Guest)is optional.
Now my printer works over Wi-Fi. Smart plugs and devices work.. and Raspberry Pi's are very very solid.
austinjenna
Columbus, Ohio
Posted: 05/24/23 04:45am Link  |  Quote  |  Print  |  Notify Moderator
As another person already posted the easiest way is just to rename each network. For me I name one of them 'yourwifiname here24' and the other 'yourwifinamehere5'
to be able to distinguish which one to connect too by just addint the '24' or '5' at the end of your wifi name.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
