Part-Timer
SE Ga
Hello all. First time poster long time lurker. I have been visiting this forum for years. You all are a wealth of information and knowledge. I appreciate all of the expertise on here and you have helped me tremendously over the last decade or so of RVing.I felt the need to create an account and post since I tried searching this forum and many others for an answer but have yet to be able to find one.
Long story short. I have a 2021 chaparral 298rls 5th wheel and a 2024 silverado 3500 gas with 10-speed allison. I have the factory gm puck system and factory curt hitch mounted in the bed holes. My rv tends to "jerk" almost like a fish biting on a line feeling but only when accelerating. Sometimes it is much more noticeable than others... it's hard to describe the feeling, it is NOT chucking like you feel when hitting expansion joints or bumps. It is almost as if the brakes are pulsing 5-6 times a second like a quick "tug - tug - tug - tug -tug" feeling. Sometimes enough to jerk the truck and occupants, sometimes more of just a feeling in the wheel, seat, and gas pedal.
This happened on my old 2022 gas 2500 truck with the same trailer and hitch. Mainly under harder acceleration between 2800-3700 rpms then goes went away after 3700 rpm or so...
I took it to the dealership and they replaced the torque converter and when that didn't fix it, they replaced the transmission pump as one of the fins on the pump had a crack after inspection. That didn't fix it either. A new transmission was on backorder at the time so I decided to trade the truck for a diesel as it was all that they had at the moment. New truck was a duramax and 10-speed allison.
The diesel occaisionally did the same thing but not nearly as noticeable... mainly just slow accelleration in stop and go traffic. But this at least let me know that it was the trailer in some way doing it and not the truck. I learned to live with it and pulled for another 5000 miles or so with 3 different diesel HD silverados all 10-speed allisons.
Fast forward to today. I traded my last diesel for a new 2024 gas 6.6 with the 10-speed allison as I really don't need a diesel for my uses. (Trailer is roughly 12,000 lbs loaded)
Figured the new allison like the diesels would feel the same, but almost immediately I noticed the jerking again under acceleration. Much more prominent with the gas trucks than with the diesel trucks.
Starting with the original gas truck I tried all kinds of trouble shooting from hitch adjustment, pin box adjustments, adding timbren ses to lessen rear sag, different tire pressures in the rear tires, filling my truck bed with hundreds of pounds of tools, filling the water tanks, emptying the water tanks etc..
Now that I'm back in gas truck I am noticing it again and it's much more prominent than in the diesel trucks. IDK if that's due to the additional weight of the diesel engine over the front axle or possibly just the additional mass lessening the "felt" tugging.
We also just replaced all the factory china bomb tires with Goodyear endurance tires after another costly blowout and still feels the same. So that rules out the trailer tires which was my last guess.
Has anyone experienced this before or have any insight? Again, it is not chucking like when you hit an expansion joint. The road can be perfectly smooth and as you start to accelerate or "pull" the trailer at more than just a leisurely pace, it'll start "tugging" 5-6 times a second. This goes away after 3800 rpm or so all the way to 5000 rpm.
With the timbren SES the trucks sits almost level, the rear is still about an inch higher than the front. My old truck had this issue both before and after the timbrens so I know it's not the angle or rake of the truck.
Any insight would be greatly appreaciated.
edited 05/24/23 11:51am by Part-Timer *
2024 Chevrolet 3500 SRW Gas 6.6 w/ 10-Speed Allison
2021 Coachmen Chaparral 298RLS
TXiceman
Bryan, TX
Is the trailer chucking? Does it do this on all road surfaces?
Have you weighed the rig to see if your loaded pin weight is about 20% of the loaded trailer weight? Too light on the pin can accentuate the chucking or jerking.
Ken
Amateur Radio Operator.
2013 HitchHiker 38RLRSB Champagne (FORSALE), toted with a 2012, F350, 6.7L PSD, Crewcab, dually. 3.73 axle (truck is sold), FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Part-Timer
SE Ga
TXiceman wrote: Is the trailer chucking? Does it do this on all road surfaces?
Ken
Hey, thanks for the response.
This motion happens on all surfaces, smooth or rough doesn't make a difference. It is not the same chucking feeling as when hitting a bump or expansion joint on a bridge or overpass.
** edited to add that I have tried pulling it with the freshwater tank both full and empty which is infront of the axle and would increase the pin weight. The full tank did not make a difference.
No I have never been to a scale to weigh it all. Per the manufacturer website the estimated pin weight is 1,935 lbs, based on an estimated dry weight of 9,574 lbs. Those two weights come from their website and the pin weight is 20.2% based on their weight measurements. The dry weight as shipped from the manufacturer per the sticker on the pinbox is 10,870 lbs.
We also added a washer and dryer to the front of the coach driectly above the pin box in the nose/closet and the propane tanks as well as battery are all on the front of the coach. The washer and dryer add about 200-250lbs to the pin weight as they are directly above it. We don't really pack heavy but the main storage is the passthrough that is directly below the nose of the coach as well as a front storage compartment below the pinbox. So the 300ish lbs of chairs/grill/metal dog fence panels etc that are below the pin on the front of the coach plus the washer/dryer being above the pin should put me well over 20% pin weight based on my rough guestimates. Again, I haven't weighed the setup but it is defintely loaded front heavy as there is no storage behind the axles. This jerking motion also happened before installing the washer/dryer into the rv.
Part-Timer
SE Ga
Also just wanted to add that the hitch and mounting points are solid. When coming to a stop or leaving from a stop there is no "slack" or "clunk" felt in the hitch or pin as I have felt with other hitches over the years.
Another note, when I am accelerating and the tugging begins to happen if I squeeze the brake controller the tugging does not stop. So if I am accelerating and say between 2800-3800 rpms I will feel the quick "tug" "tug" "tug" "tug" feeling and it will continue even if I apply the trailer brakes and continue to accelerate.
I hope that makes sense
edited 05/24/23 04:23pm by Part-Timer *
fj12ryder
Platte City, MO
That's a new one on me. I don't have a clue, since it has happened with all the trucks.
Howard and Peggy
"Don't Panic"
ssthrd
Vancouver Island
The trailer seems to be the common denominator. Wondering if the trailer suspension might have a loose bolt or two. Might be worth a look.
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
bucky
Raleigh metro
What pin box are you running?
Puma 30RKSS
Tvov
CT
Did you check all the wiring in the 5th wheel? Especially the brake wiring? Maybe there is some sort of odd cross connection or something going on. Kinda sounds like the brakes are pulsing?
2021 F150 2.7
eHoefler
ozark mountains
Short bed truck? Check location of center of hitch to center of axle
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Part-Timer
SE Ga
I haven't checked the suspension, I'll have to crawl under it when I get a chance. I will say that Tuesday morning I had 5 new tires installed and had to jack it up myself since the shop didn't have a large enough jack or stands. I didn't notice anything weird with the suspension when I had the wheels off but I did trace the wires going to and from the brakes into the axle and didn't see any cracks or chafing any where on the wires, at least the visible portions.
The pinbox is the factory pinbox that came with the trailer, its a lippert frame so I assume a lippert pinbox but I honestly do not know for sure. I can check when I get home.
Current truck is a short bed with the factory puck system, hitch is about 3 inches behind the centerline of the rear axle. However my last truck was a 3500 duramax single rear wheel with the 8ft box. Same factory puck systema and hitch but the hitch was square with the rear axle. This truck also had the occaisional tugging at low speed acceleration but less noticeable... my theory is due to the additional mass of the diesel engine. But my point is the tugging was still there with the diesel and the long bed truck.
Would a possible brake malfunction in the trailer brakes cause this issue? As-in a defect in the shoes or drums or physical hardware?
On my first truck that had the torque converter replaced, the dealer tech rode with me to feel the tugging and we pulled the trailer with and without the connector plugged in to elliminate the brake controller. The tugging was there even without power to the trailer or braking system.
Honestly at a dead end with my trouble shooting ideas which is why I made the post.
The trailer has 8600 miles on it currently but has done this since new. Always assumed it was the truck or hitch. I have blown two factory chinese trail ride tires. Again, assuming that the tires were just cheap and unrealted to the tugging. Could sticky/malfunctioning brakes cause tugging only during acceleration and only at certain rpms/linear pull loads? and what I mean by linear pull loads, it's like at certain amounts physical pulling from the truck is when this happens. It does NOT happen cruising down the road, slowing down or when applying the truck or trailer brakes to stop. Only under acceleration at just the right amount of "pulling force"
I will note that the old tires when filled to 80psi cold, would climb into the mid to high 80's after towing. Even at night with a 70-75 degree ambient temp. And the rubber compound was extremely soft and tread seemed to be melting. Like if you did a sweet burn out in a hot rod and had rubbery residue and string like particles all over your tires. That's how some of the old tires were looking while towing on our last trip and what caused me to buy new tires. I'll try to upload a picture if I can figure it out.
The new tires seemed to only go up to 83psi pulling in the florida heat on our way home during peak sun and 90 degree temps. Also no visible wear after 300 miles.
I was thinking maybe sticking brakes could cause extra friction on the tires causing them to "melt" and blow out. But it could also just be cheap/dangerous tires. Especially since the goodyears appear to not be affected the same way.
edited 05/25/23 08:21am by Part-Timer *
