RV.Net Open Roads Forum: Travel Trailers: New travel trailer Gulfstream Conquest 323tbr
 > New travel trailer Gulfstream Conquest 323tbr
PAThwacker
East Stroudsburg, PA
Posted: 05/24/23 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Got a new to us 2020 Gulfstream Conquest 323 Tbr 11,600 gvw. Way outside of half ton world. Got it delivered to seasonal site while I shop for next tow rig. Been looking only at used gas trucks from GM and ford 3/4 to 1 ton srw. Any 6.0 older gas Chevy or 6.2 ford for this trailer? How about older ford 5.4 3/4 truck?
2015 Keystone Springdale Summerland 257rl
Tow vehicle: 2003 GMC K1500 ext lb
Previous: 14 years of 3 popups and a hybrid tt
bob213
Fresno, CA
Posted: 05/24/23 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure where you got your weight info but it seems little high. Although factory numbers are usually low...7500/9800lbs. Either way a 3/4 ton should work for this trailer but I'd never walk away from a 1 ton if it was close in price. Good luck with your new trailer [emoticon]
Nv Guy
Reno NV
Posted: 05/24/23 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Having owned two 5.4 Fords, I would avoid them, as they will struggle pulling this rig. 6.2 would be a better choice.
Boomerweps
Hills of PA
Posted: 05/25/23 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Had a 5.4 in my 98 Expedition. Replaced the head exhaust gaskets, both sides, TWICE. They liked to leak. Cast iron header to aluminum head. Once started leaking it would etch into the aluminum. It only had 60000 miles on it when we sold it after 16 years.
Having the 5.4 as a base model engine in a Superduty is/was the same as getting the V6 in the F150.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
