RV.Net Open Roads Forum: Class A Motorhomes: Motorhomes with 19.5 vs 22.5 tires
 > Motorhomes with 19.5 vs 22.5 tires
IB853347201
Eastern Ontario
Posted: 05/26/23 06:42am Link  |  Quote  |  Print  |  Notify Moderator
I've owned 3 MH's. One on 16 inch, one one 19.5 inch and the present one on 22.5 inch. Every time we traded up to a larger chassis and larger tire size, the ride and drivability has improved. The 22.5 inch tire is the best by far.
2010 Suncruiser
Horsedoc
Dixie --- N. Georgia
Posted: 05/26/23 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I like the 22.5. Handling vs 19.5? Haven't driven a coach with the smaller tires but trucks with the larger tires ride better.
Certainly more available if you need 22.5 on a long trip someplace.
Run what you like.
phillyg
SWFL
Posted: 05/26/23 07:46am Link  |  Quote  |  Print  |  Notify Moderator
My old 1996, 36' gasser with a tag axle had 16" tires and handled fine. Perhaps I didn't know what I was missing.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
MrWizard
Traveling
Posted: 05/29/23 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
My 1995 34ft Safari DP, had 22.5 tires at $400 per tire,
My current RV 1997 gasser Bounder Ford F53 Chassis 16" tires, $150 per tire, the the Safari ride and Bounder ride are different , not so much in the " seat of the pants feel" but in body lean braking dip, wind stability, Its Not bad, just different i have no complaints with this Ford chassis, but the tires do wear out sooner,
None are going to ride and handle like a car, the best handle like a bus, the worst like a worn out truck,
Bigger tires means the vehicle has more weight per tire on the road a heavier Chassis and a stiffer suspension, less roll & lean than the same RV house, on a smaller tire lighter chassis
I can explain it to you.
But I Can Not understand it for you !
Connected using T-Mobile Home internet and Visible Phone service
1997 F53 Bounder 36s
Gjac
Milford, CT
Posted: 05/30/23 06:20am Link  |  Quote  |  Print  |  Notify Moderator
There are more important factors that tire size that determine how the MH will ride. Weight distribution being one, ideally each tire should carry the same load. Front end alignment being another. Worn shocks front end parts like ball joints tie rods etc will affect the ride even more. All things being equal, which they never are in real life you would not notice a difference in ride quality based on just tire size. You will notice a big difference with too much weight in the rear and a light front end or a front end out of alignment.
Onyrlef
Plano, Tx
Posted: 06/04/23 05:33am Link  |  Quote  |  Print  |  Notify Moderator
I suspect a lot of post hoc reason. The only way to conclusively determine a difference in ride and handling in a 19.5" and 22.5" tire would be in an all other things being equal side by side comparison. Otherwise the difference could be just as reasonably attributed to the upgraded shower head.
RodLyle
Almost Heaven
Posted: 06/04/23 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
We have had 3 Class A’s with the smaller tires. Our 4th and current Class A has the larger 22.5 tires, it gives a better ride . We travel quite a bet.
rgatijnet1
Posted: 06/05/23 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Driving two different coaches with different size tires is not a good representation of how that coach handles. At that time the coach is probably empty and who knows what the tire pressure is, according to the current weight. The handling is based on proper loading, proper tire inflation, proper wheel alignment, road conditions, wind, and driver experience.Any of these things can greatly affect the handling if they are out of specs or if the driver has unrealistic expectations.
way2roll
Wilmington NC
Posted: 06/05/23 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Is it really the tires that makes it handle better? Larger tires are a result of a larger chassis and heavier MH. It's not an upgrade option, it's spec'd based on the chassis and the demand for a tire that can handle a higher payload. I would guess it's the heavier weight and larger chassis that makes it handle better.
2023 FR Sunseeker 2400B MBS
Posted: 06/05/23 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the last 2 posts that actually are on the right track.
Funny thing is, from most of the rest of the posts, one could maybe conclude that putting 22.5s on a Toyota Corolla would make it handle better! Lol.
