campingshadow
Waskom, Texas
Well, as it turns out, I did contact the previous owner who has been so helpful. Turns out he never used a bypass. He blew out all the lines and put RV anti-freeze in the traps and toilet. So got the water working in kitchen and bathroom. Now, apparently the fresh water level sensor is not working as we have been filling the tank for 20 minutes and it is still showing empty. And one of the two low drain valves is dripping pretty good.
So little by little, we are getting there. Might be able to actually use this RV soon. Lol
Shadow and LD
Angel. 15 lb Toy Fox Terrier
2001 Damon Intruder. 349. Class A
Semi-retired and loving it!!!!
way2roll
Wilmington NC
Glad you got that sorted out at least and thanks for reporting back.
2023 FR Sunseeker 2400B MBS
campingshadow
Waskom, Texas
Ah, but after getting the city water to work and all faucets working……dangled if there is not another water issue. Cannot figure how to fill the water tank. Again called the previous owners and they never filled it. Just used city water hookups.
I have examined every inch of the outside of the RV and there is no water tank fill valve. In the wet bay there is a hookup for city water and directly below it another clearly labeled for flushing the waste tank. I saw pictures of Intruders - Some with clear outside hookups and some not.
Read several people talked about turning some valve on the city water to tank fill. But my connection does not have that option either. Read the owners manual and it tells me nothing.
This is getting really annoying with this RV. Something so simple as filling a tank. I have owned several RV,s and never had these kinds of issues. Driving me nuts and it is a dang short trip.
campingshadow
Waskom, Texas
Glad to report we found the fresh water fill. Not where you would expect it to be….near the wet bay. Heck no, it is on the other side of the RV……..ON THE SIDE OF THE BEDROOM SLIDEOUT ! Not under it……right on the side. Where the coach is white and so is the fill. With the slide out, never thought to look there!
Just one more mystery solved. Thanks for all the help and suggestions, guys.
It may take a village to raise a kid, but apparently it takes a lot of friendly, helpful RVers to get this gal straightened out. Still, there are more mysteries to unravel….like where is the fuse located for the HWH levelers? ??????
Dutch_12078
Winters south, summers north
Remove the drawer under the closet over the water heater to see how the panel is secured. A previous RV of ours had the panel secured by spring clips that allowed the panel to be easily popped off.
Dutch
2001 GBM Landau 34' Class A
opnspaces
San Diego Ca
On my trailer I was stumped by an access door that had trim all around it like a picture frame. Turns out the top of the frame was not connected and the whole panel slides up to remove it.
edited 06/13/23 02:19pm by opnspaces *
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
