RV.Net Open Roads Forum: Norcold Refrigerator will not run on 120-volt power.
 > Norcold Refrigerator will not run on 120-volt power.
hedgehopper
Denver
Posted: 05/25/23 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
We recently bought a Thor Axis 24.1 with a Norcold 2-way refrigerator. The switch on the fridge control panel can be set so that the fridge runs on 120-volt power when available. Otherwise it runs on propane. We discovered that the fridge always runs on propane, even when 120-volt power is available and we don’t know how to correct that. Any suggestions?
CA Traveler
The Western States
Posted: 05/25/23 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
Check that there is power at the 120V plug. Then check the fuses in the back.
2014 Grand Cherokee Overland
Bob
Scottiemom
Posted: 05/26/23 04:44am Link  |  Quote  |  Print  |  Notify Moderator
I had that happen. The outlet the fridge plugged into in the back was one of those old ones that the parts were pressed into. Over the years, everything loosened up and it wasn't making constant contact. A friend of mine, an electrical engineer put a new outlet in it and it's been running every since.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
FANC 1
Rhode Island
Posted: 05/26/23 04:53am Link  |  Quote  |  Print  |  Notify Moderator
Check the back of refrigerator see if a red light is lit on the temp limit switch. If so you need a magnetic to reset the switch. Search youtube for more info. Mine was a Norcold 1200.
dougrainer
Carrolton, Texas
Posted: 05/26/23 07:28am Link  |  Quote  |  Print  |  Notify Moderator
The recall switch shuts the complete operation of the refer down. NOT just certain parts. Doug
IB853347201
Eastern Ontario
Posted: 05/26/23 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Is the fridge set on Auto? Check the owners manual?
2010 Suncruiser
