RV.Net Open Roads Forum: 2005 Norcold refrigerator -- shore power not cooling
 > 2005 Norcold refrigerator -- shore power not cooling
TenOC
On the road -- Full time
Posted: 05/26/23 08:19am Link  |  Quote  |  Print  |  Notify Moderator
2005 Norcold refrigerator connected to shore power, temperature set number 9, mode AC, outside temperature 80°, inside temperature 70°. I cannot get the inside of the refrigerator to cool below 45° sometimes it is 50° which is unacceptable to for food storage. Trailer is level.
I have tried running on propane with no joy
Any suggestions are welcome.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
enblethen
Moses Lake, WA
Posted: 05/26/23 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Model of your Norcold?
Check fuses on circuit board
Check connectors on circuit board
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Ranger Smith
Wherever the rig is parked
Posted: 05/26/23 09:42am Link  |  Quote  |  Print  |  Notify Moderator
120 volt heater went bad??
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
TenOC
Posted: 05/26/23 10:35am Link  |  Quote  |  Print  |  Notify Moderator
The "tube" is hot so the heater is working. Likewise, all the fuses are good.
TenOC
Posted: 05/26/23 10:36am Link  |  Quote  |  Print  |  Notify Moderator
N821
dougrainer
Carrolton, Texas
Posted: 05/26/23 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
Installed in a slide room? Doug
TenOC
Posted: 05/26/23 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
No
enblethen
Moses Lake, WA
Posted: 05/26/23 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Since unit doesn't work on lp and marginal on electric, test the thermistor.
Thermistor testing
Potentially bad circuit board. I prefer Dinosaur Electronics replacements..
dougrainer
Carrolton, Texas
Posted: 05/27/23 05:44am Link  |  Quote  |  Print  |  Notify Moderator
N821 has just 1- 120 element.
1. Verify ventilation from outside lower refer access door up thru the roof is clear of obstructions. You will have to remove the top roof vent to verify upper area. Just 4 screws removes it
2. Verify your model does NOT have a 12 volt cooling fan just below the rear condensor coil. Step 1 with a flashlight will verify that.
3. If 1 and 2 check out, you then disconnect the 120 heat element from the rear control board and run 120 volts direct to the Heat Element for 24 hours. IF after 24 hours the freezer is NOT below 10 degrees and the lower refer is NOT below 40 degrees, your Cooling Unit is bad and needs replaced. Doug
dougrainer
Carrolton, Texas
Posted: 05/27/23 05:45am Link  |  Quote  |  Print  |  Notify Moderator
Thermistor testing
A BAD thermister will test GOOD most of the time. If my checkout shows a good refer, then he needs to replace the Thermister. Doug
