MrWizard
Traveling
This might prove useful to some of you, a fan that will attach to the top of your Buddy Heater to better circulate warm air, no Batteries needed, it works by using heat to create the power needed, it has a "Thermal Electric Generation" device in its base, its the reverse of the solid state DC cooling devices Used in 12v fridges and coolers,
That's what thermal couples do, use heat to create power to open a gas valve,
This makes enough electrical power to drive 2 fans.
Fan for Heater or Fireplace
I was researching Stirling Engine Devices when i came across this
last
edited 05/27/23 09:41am by MrWizard *
View edit history
I can explain it to you.
But I Can Not understand it for you !
Connected using T-Mobile Home internet and Visible Phone service
1997 F53 Bounder 36s
TurnThePage
North ID
I have a similar fan, same principle. It works well with the Buddy Heater. The base of the fan is flat to sit on a wood stove or similar. I haven't done it yet, but I've already figured out how to modify to sit securely on the Buddy.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
MrWizard
Traveling
Once mounted you will be ready for next fall
