RV.Net Open Roads Forum: Tech Issues: Kwikee Step
 > Kwikee Step
Gottahaveit
Stockton CA
Posted: 05/27/23 11:44am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2006 Mandalay MHome with the Kwikee step. The step appears to be working properly however when it retracts the motor seems to keep trying to engage (keeps clicking) for a few seconds after the step is in. We have replaced the motor in the past and just wondering if you think is trying to go out on us again ?
Not sure if it’s related at all but the sensor is acting up as well and steps only go in I close the screen first. Recently had new flooring put and not sure if it just needs adjusting.
40ft Mandalay Quad Slide
2015 Jeep Grand Cherokee Limited
enblethen
Moses Lake, WA
Posted: 05/27/23 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
The magnet needs to be adjusted to tell the step to retract.
As for the step retracting issue, I would check the connector for the control box and the two ground connections.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
RLS7201
Posted: 05/28/23 10:16am Link  |  Quote  |  Print  |  Notify Moderator
I'm going to suggest the 3 bushings have flattened, allowing the motor to keep rotating. It is a common issue that causes people to buy motors and gear boxes, when all that's needed is the bushings. The bushings fit inside of this gear.
Take the gear and cover off the side of the motor and you will see the issue.
Bushings also available from Oreilly Auto Parts, for Ford power windows
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
klutchdust
Orange, California
Posted: 05/28/23 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
The motor itself is similar if not the same as a Ford power window motor. Last one I used was 67. dollars. Qwikee steps cost much more than that.
Richard
Gottahaveit
Stockton CA
Posted: 05/28/23 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the suggestion on the bushings. It’s worth a shot [emoticon]
Gottahaveit
Stockton CA
Posted: 06/03/23 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Update:
The bushings were fine but hard gear was worn and missing teeth. Replaced with this and it works like a charm now [emoticon]
Kwikee 379160 Gear Box Linkage with A, Grey, 9 Inch
enblethen
Moses Lake, WA
Posted: 06/03/23 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update!
One giant step!
 > Kwikee Step
