johnnydiesel
New Jersey
I purchased a 2023 Ram 3500 Diesel 4x4 Crew Cab 8 Ft bed truck new from the factory and added a 20k M20 Mopar 5th wheel hitch on the build sheet. I received the truck on March 7, 2023. Before utilizing the hitch, I went over it to check all bolts for proper torque and greased all fittings, and greased the jaw and pin on the 5th wheel. On the first trip leaving the RV dealer, I noticed loud clunking when I stopped rv, and a clunk when starting pulling the RV. This clunk was most aggravating and upon arriving home, the hitch was gone over extensively. The puck system is tight and checked with a crowbar, all bolts on the hitch head were retorqued to spec, and all grease points were lubed again. On the second trip towing the RV, the clunking upon initial pull and stopping persisted. When I grab the hitch with no RV on it, the lower area of the hitch has a tiny bit of slop, but not much. I connected the RV and had the RV moved back and forth with wheel chocks on the RV, and I could see clearly the 5th wheel sliding back and forth a large amount. I measured the pin on the RV and it is 2.00 inches in diameter with a caliper. I measured the hitch jaws opening the best I could and measures 2.15 inches. It is hard to hold the jaws level to get an accurate measurement. I called my Ram dealer, and they have no room for me to bring an RV and truck there and just want to look over the hitch, but, there is not much that can be done as it all checks out for tightness and grease. The RV dealer says it is an inherent issue with the Mopar M20 hitches. Mopar customer service is not much help. It was escalated to no avail. I don't buy this as I read so many happy customers with the M20 in 2500 and 3500 trucks on the puck system. Is anyone else having this issue and what can be done other than replacing and upgrading to another hitch?
Link to loosness video:
https://drive.google.com/file/d/1VRLt7W3xn65J2cNMchBItR1Iohoop5qB/view?usp=sharing
edited 05/29/23 03:41pm by johnnydiesel *
2023 Ram 3500 4x4 Big Horn Crew Cab 8ft Bed HO Cummins Aisin Trans
2023 Grand Design Momentum 351-MS Toyhauler 8K Axles with Disc Brakes
eHoefler
ozark mountains
You can PM if you like, the pucks need to be tightened.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
southernsky
Ponchatoula La.
The Ram M20 is made by Curt. Any RV shop who sells Curt can help you out
2022 Renegade Super C
2020 Ford Ranger 4x4 Sport
Cummins12V98
on the road
ASK for your money back and get a B&W. You WILL thank me!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
OH, let me know how easy it is to unhitch the CURT what the truck and RV are not in the same plane.
