RV.Net Open Roads Forum: Tech Issues: Remote measurement of fridge and freezer temperatures
 > Remote measurement of fridge and freezer temperatures
hedgehopper
Denver
Posted: 05/28/23 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
Have you found a good instrument for remotely measuring the temperatures of fridge and freezer?
I have been using an Acurite. It has been satisfactory except that when the batteries in the remote go dead the base station continues to give the previous reading and you don't know the batteries are dead.
Also the magnets that secure the base station to a metal surface came loose from the base station and when re-attached seem to have lost their magnetic properties.
So I am looking for something better. What has worked well for you?
* This post was edited 05/30/23 04:29pm by hedgehopper *
Dutch_12078
Winters south, summers north
Posted: 05/28/23 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
This one from Acurite has worked well for us since 2016:
https://www.amazon.com/gp/product/B004QJVU78/
Dutch
2001 GBM Landau 34' Class A
hedgehopper
Denver
Posted: 05/28/23 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
That's the same one we have been using. How do you tell when the batteries in the sensor go dead?
Second Chance
Wherever...
Posted: 05/28/23 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Look into the YoLink systems. I don't monitor the temps in our residential fridge (it has digital readouts on it), but I monitor the temp in the basement, have water leak sensors in various places, and a power failure alarm that turns of some smart power strips so unneeded things don't drain the batteries (via the inverter) when just on batteries and solar.
YoLink on Amazon
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
vermilye
Oswego, NY, USA
Posted: 05/29/23 08:37am Link  |  Quote  |  Print  |  Notify Moderator
If you carry a "Smart" phone, check out the SensorPush (Link). Long range bluetooth connection, logging over day, week, month, etc. I have one in the freezer & one in the refrigerator section. (I also use one for outdoor temperature.)
Jon Vermilye My Travel Blog
My Photo & RV link blog
Flyfasteddie
Idaho
Posted: 05/29/23 08:56am Link  |  Quote  |  Print  |  Notify Moderator
I use the same one. I have Eneloop rechargeable batteries in them and I just replace them with freshly charged ones once a year.
fj12ryder
Platte City, MO
Posted: 05/29/23 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
How remote are talking about? Just with the doors closed in the trailer? Or if you gone from the trailer and want to check it?
Howard and Peggy
"Don't Panic"
Posted: 05/29/23 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
The problem with battery operated RF remote sensors in the fridge and espically in the freezer is .. The batteries tend to not work. (And the frequency may drift)
Beyond that I can not say much.... Now designing a sensor.. It's easier than you think.. inside that Accurite is a small blob known as a thermisistor.. You need to remove it and "remote" it. (Add leads) then route the wires (There is already a path as there's already a thermisistor inside the fridge and a water line into the freezer) and hook the leads back to the sender OUTSIDE where it's warmer.
Alas.... I can not help you there. You will very likely destroy the thermistor (They are cheap but I know not the value> How cheap. oh 10 bucks for half a dozen give or take)
If they are the right value.... Well 3-D printers tend to eat 'em.
fj12ryder
Platte City, MO
Posted: 05/29/23 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW the ones in my fridge and freezer have been in use several months easy and still going strong. But they are just to use while in the trailer, not with a phone or networked. I love 'em. No idea what brand, prolly just a cheap no-name from China.
hedgehopper
Denver
Posted: 05/29/23 11:41pm Link  |  Quote  |  Print  |  Notify Moderator
I want to read the fridge and freezer temperatures without opening the fridge and freezer doors.
