RV.Net Open Roads Forum: Tech Issues: Water pump sucking air
 > Water pump sucking air
BobsYourUncle
Calgary Alberta Canada
Posted: 05/31/23 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
Does the tank have a gravity fill port on the outside or is it pressure filled from the water hookup point? If it's pressure filled from the water hookup point are you sure water is making it to the tank?
If gravity fill does water come out the vent hose when full? Or does it only spit water back out around the hose?
Gravity fill port outside the TT.
I fill it until it is right full, and coming back out the fill port.
100% for sure the tank was full to the top.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
