Weetomah wrote: Thank you for your reply. No, we don't have a park model. The only things that we have a T handle on are the drains to empty the black and gray water. We are looking for a way to drain the remaining water out of the fresh water tank so it does not stay in the tank for too long once we get home, especially if we are not going back out again for awhile.
find your fill cap, then look under the rv at around that point and there should be a hose with a cap or valve on it hanging down (might look like a 3rd low point drain) that should be your way of emptying the freshwater tank.
the two low point hoses drain the water in the plumbing. the fresh water tank won't be too far from you fresh water fill. the drain for the fresh water tank could be anywhere.
my tank is between the axles and the drain is in the front under the tongue which is about 12 feet from the tank.
