RV.Net Open Roads Forum: Travel Trailers: Best Fridge Type
Dutch Oven Man
Tennessee
Posted: 05/30/23 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
We have had 2-way and 3-way fridges for years. I need to replace out discontinued Atwood unit that is a headache, and have been reading about the 12V compressor fridges. We are 99% RV Park type folks, only time we are boondocking is for an occasional overnight stop at Walmart, and even then I have a generator.
The 12V units seem to be more economical and larger for the same size cutout than the 2 way units, downside being they can drain the battery when not hooked up to shore power.
We have a 15 year old travel trailer and have no desire to go Lithium, so would a 12V be advisable for travel and being plugged into shore power. Brand preference or brand to stay away from? I don’t want the Atwood “no longer supported” headache I have now.
joelc
Cedar Point, NC
Posted: 05/30/23 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
I got a Dometic 12V fridge. It runs, but must have a special guage wire for it to run properly. Also, if something goes wrong, you might as well pray, cause you cannot get parts for it. I believe my thermostat is faulty, but can not get one unless I fork over $170 and wait 6 months. It runs well as long as it is on maximum setting. I am assuming all units that you look at that are made in China will have the same problem They are interested in selling them, but don't want to supply parts so one can repair it.
QCMan
Independent Republic of Horry
Posted: 05/30/23 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
20 years and zero issues with any of the propane/120 Dometics we have had and they have the added bonus of having a backup system. No large draw from the batteries and it does not use much propane either. I may be a dinosaur but the only enemy of absorption reefers is the folks that own them. If you keep the flue and airway clear of webs and nests a unit will last a very long time. And perform well as long as it is not in a slide. JMHO.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
IB853347201
Eastern Ontario
Posted: 05/31/23 05:38am Link  |  Quote  |  Print  |  Notify Moderator
From what I have seen and heard, the newer 12V compressor models are the way to go. Especially if you don't boondock a lot. Just the increased cubic capacity and ditching all the issues that come with a Propane unit make it a winner for me. Most of the new TT's are equipped with these. Most are Norcold with service and parts readily available.
2010 Suncruiser
John Burke
North Dakota
Posted: 05/31/23 06:24am Link  |  Quote  |  Print  |  Notify Moderator
May want to consider a residential fridge that would fit in the space. The area already has a 120-volt outlet there that you could change the power source to an inverter. If you all your time in shore power or generator a inverter and a good battery will carry you between hook ups. Fridge will be much cheaper, and you will not have to run a heavy gauge wire for a 12-volt unit.
I have a 120 unit in my cabin that runs off an inverter, battery and solar, have had propane in campers for years and just got a camper with a 12 volt. The new camper has 2 group 31 batteries charged by 2 190-watt solar panels anthe fridge has been running in the driveway for 6 days now.
In your case I would probably put in a propane unit. No changing wiring or running new stuff. Just install and go.
valhalla360
No paticular place.
Posted: 05/31/23 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Our latest fridge came with 12v compressor fridge. So far with 3yrs loving it:
- Easily 50% more interior space for the same cabinet space.
- Cools much more quickly (both on start up and when you put food in after shopping).
- Only draws about 50w when running (4amps@12v) and it doesn't run all the time.
- We have 2 - standard 12 batteries and it easily handles an overnight. If you want multiple days, solar can get you there but since we only boondock occasionally, charging from the truck while driving or running the generator for a couple hours does the trick.
- I wouldn't worry too much about getting parts. 12v compressor fridges are becoming the standard on new RVs, so if anything in 10yrs,absorption fridges will be more likely to have issues finding parts as they fade away.
A residential 120v AC fridge would be an option but then you need an inverter to run it while not connected to shore power.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Rickyrocket
Coventry,RI
Posted: 06/06/23 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
They work awesome but they suck down the battery when boondocking
TurnThePage
North ID
Posted: 06/06/23 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
My new trailer has a 12v fridge. We just camped 3 days 2 nights with one group 24 battery. It has a solar panel, but we were under trees.
However, my last trailer had an absorption fridge that is still flawless after almost 20 years, and could run most of the summer on a 30lb propane tank a little 12v juice.
My new Furrion 12v fridge makes quite a bit of noise when it periodically kicks on.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
wowens79
Georgia
Posted: 06/07/23 06:26am Link  |  Quote  |  Print  |  Notify Moderator
I really like my 120v fridge. We have always camped with hookups, there just isn't much boondocking in the southeast. With 2 6v GC2 batteries we have done 12 hours on the road with no issues.
It cools really quickly, we can't keep the camper at the house (HOA) so we bring the camper to the house the night before we leave and load that night. The fridge is cold in a couple of hours.
Honestly, the fact it is not made by an RV parts supplier gives me more confidence in the fridge. I keep reading about issues with the Furrion fridge with the controls acting up, and the doors coming open in travel. You would think an RV fridge manufacturer would know they bounce around and the doors need to be secured.
2022 Ford F-350 7.3l
2002 Chevy Silverado 1500HD 6.0l 268k miles (retired)
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
Bobbo
Wherever I park
Posted: 06/07/23 07:02am Link  |  Quote  |  Print  |  Notify Moderator
As long as it is propane/120v, I will be happy. If it happens to be propane/12v/120v, that is fine. I will just never run it solely on 12v.
Bobbo and Lin
