For those that have a 1090 or 1095, how did you mount it? We have a 2019 Tiffin RED 37BA and want to mount it to the right of the driver. Have not tried to mount it at all, yet.
Well my Garmin RV990 I asume is similar. The suction cup stopped working and I ended up screwing it to the center overhead. Depends on how much a couple of screw holes bothers you in the dash.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
agesilaus wrote: Well my Garmin RV990 I asume is similar. The suction cup stopped working and I ended up screwing it to the center overhead. Depends on how much a couple of screw holes bothers you in the dash.
Thanks. I assume you mean RV890. We don't mind using screws when needed.
Hi. To mount our 1090 we purchased a flat plate from Amazon that has an adhesive sticker on bottom to attach it to our dash. Our dash is not smooth so the suction cup provided does not stay attached. The flat plate must be same size or larger than the suction cup or it will not work.
We love the unit and certainly enjoy the large screen.
dkilley wrote: Hi. To mount our 1090 we purchased a flat plate from Amazon that has an adhesive sticker on bottom to attach it to our dash. Our dash is not smooth so the suction cup provided does not stay attached. The flat plate must be same size or larger than the suction cup or it will not work.
Great idea. Do you have a link? My initial search found a lot of metal ones, a few plastic but many of the plastic have rough surface.
