RV.Net Open Roads Forum: Travel Trailers: Mystery leak
 > Mystery leak
d1h
Indiana
Posted: 05/31/23 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Just discovered my 12 year old TT is leaking from somewhere. The floor under the sheet vinyl floor covering is gone. You press down on it and its hollow underneath. Its right up against the wall in the front bedroom and probably comes in three or four inches. No stains on ceiling anywhere. Wall is solid when pressing on it. Possibly coming in between the wall? Don't know what to do other than glob massive amounts of roof caulk everywhere in hopes of finding the right spot to prevent further damage. Floor must be nothing more than particle board to disintegrate like that. Is it pretty much inevitable that when an RV gets old it is going to leak at some point? I'm sure getting repairs done would be more than its worth.
CA Traveler
The Western States
Posted: 05/31/23 10:38am Link  |  Quote  |  Print  |  Notify Moderator
All openings are potential leaks, fan, seams, A/C, windows, lights, etc. Or plumbing.
2014 Grand Cherokee Overland
Bob
klutchdust
Orange, California
Posted: 05/31/23 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Leaks can travel long distances along rails, boards, wiring etc. Look for the obvious then go from there. Also what he said ^^^^
JBarca
Radnor, Ohio, USA
Posted: 05/31/23 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
I may be able to help, but we need more to give more specific help for your camper.
A few questions to start the discussion.
1. Make, year, and model of the camper so we can look up the floor plan to add context to your wording.
2. Does the camper have fiberglass or corrugated aluminum siding?
3. Are the wall studs, floor joists, and ceiling framing (rafters) made from wood or metal?
4. You stated this
Which wall shows the floor damage, the front wall, left side wall, right side wall? Left is the driver's side wall or non-door side wall.
5. Do you know if the walls, ceiling, and floor have fiberglass batt or solid foam block insulation?
6. Do you know what type of roof membrane you have?
7. Any chance of pictures of the inside damage and the outside of the camper showing the outer walls, floor to roof?
Pending the answers to the above, there are ways to investigate where the leak or, more likely, leaks are coming from and how far they have spread before tearing into the camper for repair. I have successfully used a moisture meter (many, many times) to scan the camper and see inside the walls, ceiling, floors, and roof. I'm willing to share how to do this, but we need more information to help better fit your situation.
Hope this helps,
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
joerg68
St. Ingbert, Germany
Posted: 06/01/23 03:15am Link  |  Quote  |  Print  |  Notify Moderator
If you do not know how to post pictures here, go to
http://photoposting.is-great.net and follow the instructions there.
(I am not affiliated with that site - forum member 1492 created it to make photo posting here less complicated)
midnightsadie
ohio
Posted: 06/01/23 05:08am Link  |  Quote  |  Print  |  Notify Moderator
might have it pressure tested will show where leaks could be.
Posted: 06/01/23 07:38am Link  |  Quote  |  Print  |  Notify Moderator
It only leaks at seams and holes. Don’t have to guess too much. And it’s likely any of the seams on the front cap, clearance lights or side seams nearby.
If the walls and roof don’t show any damage, don’t go exploring.
And floors are easier to fix than walls or roofs.
mosseater
Dillsburg, PA
Posted: 06/01/23 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
On ours, I found travelling in the rain with the roof vents open creates a negative pressure which will pull in rain as you travel. Carpet under the slide overlap was always wet when we towed in the rain. No obvious leak anywhere. Drove me crazy until I figured it out.
Sunset Creek 298 BH
Posted: 06/02/23 02:54am Link  |  Quote  |  Print  |  Notify Moderator
^Sure seems that the effect would be exactly opposite. Like it is for any other vehicle in motion….
Air pressure is lower outside the vehicle due to air speed compared to inside the vehicle.
mosseater
Dillsburg, PA
Posted: 06/02/23 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't disagree with your theory. All I know is, when I close the vents, the leak disappears.
 > Mystery leak
