RV.Net Open Roads Forum: Tech Issues: Is replacing the furnace worth it?
 > Is replacing the furnace worth it?
TenOC
On the road -- Full time
Posted: 06/02/23 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
mtnbbud wrote:
When I camp with shore power, I've been using an electric heater. When I need heat when dry camping, I've use a Little Buddy Heater while being careful to monitor with a CO detector and cracking the vents.
My Little Buddy Heater has been performing just fine although I hate using those little disposable propane tanks. Being that the cost of a new furnace or quality diesel heater is so high, would it be worth the upgrade?
Connect the Little Buddy Heater to a 20 or 30 lb tank. I ran the line from my Kitchen (under a drawer) to the hole I drilled at the outside shower location. I have a two burner Big Buddy heater.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
Scottiemom
Posted: 06/03/23 04:34am Link  |  Quote  |  Print  |  Notify Moderator
You might try Northwest RV Supply in Eugene, Oregon. I don't know if he has furnaces, but he has motors, parts, galore.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
enblethen
Moses Lake, WA
Posted: 06/03/23 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Good chance your furnace is a Hydro Flame now Atwood
Motors are fairly economical. Easy to replace.
For example
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Dutch_12078
Winters south, summers north
Posted: 06/03/23 09:21am Link  |  Quote  |  Print  |  Notify Moderator
mtnbbud wrote:
I'll have to look up the make and model when I have time. It's a 1989.
I don't store my trailer at my house. I do remember checking Amazon for an exact replacement of the whole unit and it was over $700 to replace it with the exact unit. I'd assume replacing the fan would be a lot less. It might be a Suburban...
Suburban replacement motors are more expensive than Atwood/Hydro Flame motors, but are still a lot cheaper than a new furnace.
Suburban Furnace Fan Motors
Dutch
2001 GBM Landau 34' Class A
StirCrazy
Kamloops, BC, Canada
Posted: 06/04/23 06:25am Link  |  Quote  |  Print  |  Notify Moderator
I have a 1991 camper with a hydro flame in it and I just replaced the motor for the furnace last year. pretty It's a pretty easy job but there are two different style motors listed, and they have different shaft lengths, so you have to watch out for that.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
mtnbbud
Oregon Willamette Valley
Posted: 06/04/23 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. I'll likely pull the furnace out sometime when I get the urge to do some tinkering. It certainly wouldn't be a big deal to pull the motor out if and when that happens. Even if I didn't fix the furnace, I could repurpose that space for storage or something.
enblethen
Moses Lake, WA
Posted: 06/04/23 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
You should be able to replace motor and other parts without removing the furnace.
Posted: 06/04/23 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
I do not think the new furnaces are all that much different in terms of battery drain.... But if you only park where you have decent electric a Ceramic type Space hearer is compact and operates at a lower temp than the hot wire type. >DO however make sure the tip over switch functions properly. If you often park w/o reliable electricity. (and from the battery draw question I suspect you do) disregard that part of this post.
Dutch_12078
Posted: 06/04/23 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
That's true for some models, but not all. The Atwood/Hydro Flame 8500 and 8900 series are easily accessed without removal, but other models and most Suburban furnaces, not so much.
