5th Wheeler JJ
Pa
I have a 2023 Jayco 31MB, it comes with a four-star handling package, which includes shock absorber mounts.
The distance between the mounds is 10 1/2 inches.
The only shocks I found that might fit, have a 7 1/2 inch compressed length
Which would only give a 1 inch of stroke so that won’t work.
The dealer email jayco a month ago and still got no reply!
What’s up with that! I think I discovered a design flaw.
Just wondering if anyone else ran into this problem or may have found shocks that fit.
enblethen
Moses Lake, WA
Look for identification tag on your axles to determine who made them. Check etrailer for some. Possible Dexter
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rhagfo
Portland, OR
5th Wheeler JJ wrote: I have a 2023 Jayco 31MB, it comes with a four-star handling package, which includes shock absorber mounts.
The dealer email jayco a month ago and still got no reply!j
What is the extended length?
5th Wheeler JJ
Pa
12”
sayoung
Tx
On my 2011 Jayco Eagle the axles are on the bottom of the spring I used Monroe 555025 . IIRC etrailer has 2lengths & the longer one is the yellow ( same as Monroe ) & a shorter black one Monroee does have an online chart with the demensions and travel lengths.
5th Wheeler JJ
Pa
Thanks for the info.
Goostoff
Wisconsin
Here is a lipert option.....Lipert RV shocks
1993 Chevy C3500
2005 Cedar Creek 34RLTS
5th Wheeler JJ
Pa
I tried the yellow ones they have an 8 1/2 inch compressed length could not even get the stems in the holes.
The black ones (standard)are the ones with the 7 1/2 inch compressed length which if you do the math with the bushings you lose approximately 1 1/2” with the bushings, so that only leaves about 1 inch or so of stroke, if they would even fit in the holes. I only have 10 1/2 inches between the mounts.
I contacted Lippert and dexter axle, and they couldn’t even give me an answer.
ScottG
Bothell Wa.
When I installed shocks on my last TT, I found Monroe had a line of trailer shocks. They worked well for me.
5th Wheeler JJ
Pa
Tryed every where, auto parts, dexter, lippert , etrailer.
That’s where I’m thinking a Jayco welded the upper bracket to the frame in the wrong place, that’s why I can’t find a shock that will fit.
