RV.Net Open Roads Forum: Travel Trailers: RV decision
 > RV decision
spoon059
Just north of D.C.
Posted: 06/04/23 11:20am Link  |  Quote  |  Print  |  Notify Moderator
OP, I'm sure you're right that RVs from the last 2 or 3 years are lacking in quality. I think that probably applies to trailers, 5th wheels and motorhomes alike. They were slapping them together as quick as possible and selling them as soon as they were made.
For your first RV, I always recommend buying an older used one. Generally you need to figure out for yourself what type of rig you want. Maybe you want bunk beds for grandkids... maybe you don't. Maybe you want an outdoor kitchen... maybe you don't. Maybe you want a bigger unit, maybe you don't. You might think you want one thing, but when you actually start camping and see how you use the space you may change your mind.
As others said, will you be in a resort setting or state forest setting? Are you camping for a weekend at a time or month at a time? Are you making reservations a year in advance and possibly camping in the rain, or last minute trips where you can avoid bad weather? Are you making meals inside, or are you cooking outdoors, or are you going to restaurants? Do you need space inside for TV, naps, crafts, etc?
Then you throw in the Covid influence on slapping them together as quick and cheap as possible and I would strongly recommend not buying new.
My family LOVES camping. Rright now we are in the season of life with softball and baseball games/practices in spring and fall, so camping has been been relegated to just the summer and our yearly Florida camping trip in the winter. We usually cook most meals at the camper, some inside, some outside. We need sufficient room inside the camper for stormy weather with three kids 10 and under. Until about a year ago, we needed a quiet spot for the youngest to nap while the rest of us were out and about. We camp at resorts, we camp at state parks. We do weekend trips, we do 3 week trips.
It's very fun, very educational for our kids. But there are pros and cons to camping and the style of camping and the style of camper. The moral of the story is that its going to be quite difficult to determine where your style of camping fits until you've done it for a little while. Best to buy a used rig so if you decide you want to change it out in a year, you can probably get most of your money back when you sell it.
Good luck with your decision. Like I said, our family LOVES camping. We are planning a cross country trip when I retire in 3 years. The wife and I are hoping to continue to camp as we age, as long as we are healthy and able to do so.
2015 Ram CTD
2015 Jayco 29QBS
theoldwizard1
SE MI
Posted: 06/04/23 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
That said, if you are reasonably handy, it's not nearly as big of a deal as they make it out to be. Biggest thing is to keep it sealed up so water doesn't get in.
That can be very difficult to do !
The typical rubber membrane roof deteriorates in direct sunlight. It needs to be washed at least once a year and sprayed with a UV protectorant (twice a year if you live in the southern US and store outside).
Despite what manufacturers will tell you, no caulk/sealant lasts forever.
valhalla360
No paticular place.
Posted: 06/04/23 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
The membrane itself is typically warranted for 15-20yr. Very rare for the membrane to actually leak (assuming you don't poke a hole in it with a branch or similar)
It's the seams where you cut into the membrane to put in hatches and other items and along the edges where leaks typically happen.
Your last statement is correct but no manufacturer I've heard of suggests the caulk/sealant lasts forever. In fact, they typically won't honor warranty work if you haven't been keeping up on it.
* This post was edited 06/12/23 07:57am by an administrator/moderator *
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
trailer_newbe
Tucson
Posted: 06/10/23 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
No doubt older trailers were built better than the ones today (generally speaking). However when you buy an older used trailer you are inheriting all the handy work, repairs and damage from previous ownership. Not a deal killer but it means the inspection process needs to be much more in-depth and you need to know where to look and what you are looking for. Most everything can be corrected and helps with getting them to lower the price. The #1 thing you want to walk away from is WATER DAMAGE from the roof, seals and plumbing. Small leaks that were corrected quickly don’t result in water damage but many RV owners don’t know something is leaking, or if they let it go for too long before trying to do something about it. Many times their attempted repair doesn’t work because they either don’t want to spend the money or don’t understand what they are dealing with. Run away from trailers like this because the water damage you see is usually just the tip of the iceberg.
2018 Jayco White Hawk 28RL
Mayborn1
Posted: 06/10/23 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
That’s the concerning thing. I’ve know people who were able to cover up signs of water damage on houses with a little paint and other tricks. I’d definitely want to hire a reputable RV inspector considering that this will be our first RV.
Peg Leg
Anderson, IN
Posted: 06/11/23 12:25am Link  |  Quote  |  Print  |  Notify Moderator
Being in Florida puts you in the best area for a used unit. Like you I'm "handy". RV's are put together in sub module units. You may have study a bit on how to access something you want to fix. Don't let it scare you.
The wife and I spend 5 months in Florida in our 34' 5th wheel with 3 slides and are quite comfortable. We've had truck campers, Class C MH, 31' TT and a couple of 5th wheels.
Get out there and enjoy while you still can.
Roofs, our TT had one piece alum sheet. To work up there you had to play leap frog with a couple of plywood squares to spread the weight out. It never leaked, even after looking like a dimpled golfball after a hail storm. We bought it new and had it for 18yrs. One 5er had a rubber roof, not impressed. Our present 5er has a PVC roof, love it. I built a antenna boom out of PVC once thinking I'd get a yr or 2 at the most. It suvived over 10 yrs, 30ft in the air in central Indiana. I wash it with Turtle Wax car wash soap and it's so white you best wear sunglasses.
I've replaced a bedroom slideout floor, changed carpet out for a vynil floor, redid a bathroom floor and the with some help from the wife we replaced two axles that got recalled and all the hardware from the lug nuts to the schackle mounts. Some floors have soft spots, beware of water intrusion but I've had 2 caused by deterating styrofoam. In my case I think mine have been from all my weight being placed in a small area from useing crutches.
Some times I enjoy working on my rig and other times I can get fustrated. Oh well, I still say go for it. Sit down and try to think of things you would like to do. Go to an RV show and write down things you like and things you don't. Then for a 1st rig, I'd try to find a reasonably priced used unit.
My in laws liked a new 5er with a front living room and a rear bath. Before the 1st month was out they hated it. I bought a pop-up truck camper that had damage but something I though I could fix. We didn't plan on keeping it long. One trip, 13,000 mile over 2 months to Alaska. After being in larger units we called it Nabisco, our cracker box but what a trip.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
deltabravo
Spokane, WA
Posted: 06/12/23 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Mayborn1 wrote:
If I go with a travel trailer I will be limited by my tow vehicle (2019 GMC Sierra 1500 4x4) which I estimate to be in the 5K to 6K range.
Never "estimate" things like tow capacity, weight ratings, etc. Find the actual specs and then go from there.
I'd be really surprised if the tow rating on your truck is that low. Heck, my 2017 Colorado has a 7000+ lb tow rating.
Mayborn1
Posted: 06/12/23 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
My tow limit is 9400 lbs. I don’t want to max that out but I would like to get a decent size RV that my wife would be happy in. We looked at a few 24’-28’ units and the 25’-27’ seemed to be the sweet spot for us.
 > RV decision
