RV.Net Open Roads Forum: Travel Trailers: Strong urine smell in bathroom
Open Roads Forum  >  Travel Trailers  >  Small TT's
 > Strong urine smell in bathroom
opnspaces
San Diego Ca
Posted: 08/01/23 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
In an earlier post you were trying to conserve water by only flushing urine after a few uses. The forum suggested flushing after every use. Now that the dealer has supposedly cleared a clog are you still flushing after every use? Or are you now letting the yellow mellow in the bowl between uses?
When flushing does the fresh water appear to fully wash down the sides of the bowl?
Here's a thought to determine if the smell is leaking out of the black tank or if it is leftover in the bowl after flushing. Turn off the water supply and turn off the water pump. Hold the toilet flush open until the pressure is out of the lines. Now get a gallon of Pine Sol and carefully pour it all into the tank while somebody holds the flush valve open. Turn on the water supply and put some water in the toilet.
Run the vent fan and purge the Pine Sol smell out of the bathroom. Let it all sit in the heat and come back later and check for smell. Do you smell Pine Sol after a few hours?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
pbitschura
SE MN
Posted: 08/02/23 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Excellent suggestion. We have been flushing regularly and allowing extra water to wash down. I will be doing the pinesol test. thanks.
2020 Braxton Creek 24fb travel trailer
dieseltruckdriver
Black Hills of SD
Posted: 08/02/23 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Also, make sure you don't have the vent fan on when you flush. That just draws odors from the tank to the bathroom area.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
pbitschura
SE MN
Posted: 09/14/23 09:52am Link  |  Quote  |  Print  |  Notify Moderator
pbitschura wrote:
Our new to us trailer on it's first voyage has a strong urine smell beginning in the bathroom and after pumping permeates the whole trailer. It's a dometic toilet. It appears to be tight and no seal leaks, I could find. I suspect it's a venting issue. Granted, it was 90 and we stayed hydrated so there is that. But black tank level was 1/3 full. We have not used any tank chemicals other than Galgon to this point.
help please.
Follow-up. We have used the camper this fall with daytime temps around 70 and night time in the upper 40's. No smell issues or other problems. It appears that at warm outdoor temps, the fan or other strategies must be employed for the bathroom to clear of smell because air will not vent through the stack efficiently enough to do the job. Aside from spray cover-ups, there will be a smell issue in the bathroom.
Rickyrocket
Coventry,RI
Posted: 09/27/23 08:35am Link  |  Quote  |  Print  |  Notify Moderator
I would get on the roof and pull the vent cap off it should be a long straight shot most of the way with a good flashlight you can see if it is blocked my previous rv had a bees nest completely blocking it.
Vintage465
Prunedale CA.
Posted: 09/27/23 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
help please.
So, had the same problem and after much washing, sanitizing, dumping, cleaning I found the problem...well, at least, our problem. 1st question, is your Dometic Toilet all plastic. 2nd questions, do you flush the toilet after every use-ish. Asking, because, we have a plastic Dometic and while we were boon docking we got into the habit of not flushing the toilet after urinating a few times in a row. With the Dometic plastic toilet I've found that if there is more than and inch or sow of liquid in the bowl, it will seep into the area between the outside of the toilet and the bowl and just sit there and ferment. I found this out when the smell just recently got so bad I removed the toilet and took it outside and when I tipped it back to check the bolt down flange seal all this nasty yuk came pouring out............thank goodness I did this outside! I took the toilet all a part to investigate the cause and the seal that the flush gate seal to is only for that and not to prevent liquid from getting into no-mans'-land between the bowl and the outside. Yes, I'm going back to the Thetford Aqua-Magic Toilet with a China Bowl. Never had this issue til we replaced the Aqua-Magic......cause I broke the bowl on the Aqua-Magic.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
