RV.Net Open Roads Forum: General RVing Issues: Rank your RV issues
 > Rank your RV issues
Samsonsworld
West Texas
Posted: 08/16/23 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Broken slides....I'll never cable slides again.
Air conditioning....not cooling good enough
Shoddy parts and workmanship...things breaking too easily, not properly aligned, tub not caulked
Refrigerator....this one is current...not cooling on propane.
I've only had one blow out and the tires were junk. Nobody to blame but me. I spend more on good tires now.
Horsedoc
Dixie --- N. Georgia
Posted: 08/17/23 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Over the 23 years (4 coaches)
!. Slide out issues (motor driven cable was far the worst)
1b. Lack of proper adjustment on motor driven cog slide
2. Electrical folding bed (sleep number) No power reaching motor
3. Fogged windows driver and passenger side
4. Plastic coating on front of coach (2 coaches)
mosseater
Dillsburg, PA
Posted: 08/17/23 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Roof leak at transition from tin to rubber at the top front of the roof. Too much dependence of caulk in too many places. Poor frame spring hanger placement/axle alignment from new. Cheap oem tires. Unreliable tank sensors. Overall medeocre build quality/fit and finish.
Sunset Creek 298 BH
Veebyes
Posted: 08/17/23 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Fifteen years, well over two thousand nights, two hundred fifty thousand truck miles, estimated well over 150,000 trailer miles, seldom more than three nights one spot. Yeah, we have had our share of problems.
Slide problems with two of the three, fridge problems, A/C problems, ATS relaced, charger replaced, inverter replaced, two tire blowouts, landing jack problems, broken springs, windows replaced twice, stove replaced, roof recoated. It goes on and on.
The good news is that with almost everything except fridge and A/C replacement we did the labour ourselves.
2007 Alpenlite 34RLR
frankwp
Calgary, AB, Canada
Posted: 08/24/23 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
Tires. I've spent more on blowout damage than all other repairs combined.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
ford truck guy
Pennsylvania
Posted: 08/24/23 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
cable slide issues..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
SoonDockin
Oklahoma
Posted: 08/24/23 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Mice, my previous Forrest River Solera had a super highway open underneath that allowed them to get inside our cabinets. Poop and pee all over out pots and pans. I crawled all under the rig and finally spotted where they failed to foam fill one 2x2 area. I stuffed it with copper mesh and sprayed a liberal amount of black foam in there. No more mice in the passenger area. But the MB Sprinter chassis diesel left a nice path for them to build a huge nest in the engine air inlet. They also chewed a few wires under the hood.
So we built a building and parked it inside. No more mice issues.
Other than that, things have been pretty good over our 9 years of camper ownership.
2022 Ram Laramie 5500 60" CA New pic soon
2018 Arctic Fox 1140 Dry Bath
Sold 2019 Ford F450 King Ranch (was a very nice truck)
jffnkrn
peoria
Posted: 08/31/23 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Over 20 years for us with 7 different trailers: bumbper pull X 4 and now on our 3rd fifth wheel, I won't go previous to the tent era.
Lots of simple issues from dead batteries, light bulbs, black tank valve, slide issue, tire, awning, etc. big deal was bent springs, and as recently as this week, A/C blew its factory charge crimp. Installed a valve and up and running. Ours, some of becasue of weather and life, But all in all lots of ours have been normal. Knock on wood, if there is real wood anywhere, never had to replace anything major. How many issues are due to lack of maintenance or non use due to storage: HMMMMM
opnspaces
San Diego Ca
Posted: 08/31/23 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
More issues with black tank than anything else. First one split stem to stern dumping the contents on the ground. Replacement has had two leaks in the cleanout sprayer and three valves needing to be rebuilt/replaced.
Second on the list it a roof leak. I spotted it as a patch of bumps like BB's under the TPO but before it stained the interior. Had to cut the roof open to dry out and use copious amounts of Eternabond to seal it back up.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
StirCrazy
Kamloops, BC, Canada
Posted: 09/01/23 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmm issues in order eh..
#1 issue is work done by supposed rv techs at the dealership.
#2 weird round spots popping off gel coat in a certain area..
#3 auto transfer switch failure.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
