RV.Net Open Roads Forum: Class C Motorhomes: Help 2011 Itasca Cambria 30C
 > Help 2011 Itasca Cambria 30C
jlpinchin
Posted: 09/02/23 04:38am Link  |  Quote  |  Print  |  Notify Moderator
We just bought the above coach, The One Place panel that starts, stops the generator, water pump, shows the tanks levels, etc, has no power to it. Thanks
* This post was edited 09/02/23 04:58am by jlpinchin *
MDKMDK
Free(er), for now, until the next "variant"
Posted: 09/02/23 05:45am Link  |  Quote  |  Print  |  Notify Moderator
Check that the coach/house battery switch is "enabled" (coach batteries are "enabled"). Usually near/in the stepwell, near the side entry door.
If not, consult the Owner Manual if you have one, or go to the manufacturer's website and download.
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
enblethen
Moses Lake, WA
Posted: 09/02/23 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Check fuses in the 12-volt power distribution panel. Often located behind metal plate adjacent to the 120-volt circuit breakers.
Some panels have fuse behind the display.
Winnebago/Itasca has manuals and drawings on website. Winnebago
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
klutchdust
Orange, California
Posted: 09/05/23 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
My 09 Cambria had some fuses in the storage area closest to the door on the outside of the coach. . There was a carpeted panel that was removable and they were behind there. Can't remember what they serviced.
Also there was a GFI at the sink area that was part of the inverter hook up. It tripped a few times and caused some interesting loss of power in the coach.
I have had issues that were power related and to find wiring that did not make any sense why this was connected to that was not uncommon.
Remove that panel and trace some wires. i was second owner and original owner added a switch eliminating that panel to start the generator. You may have power but the panel is toast.
