RV.Net Open Roads Forum: Travel Trailers: Travel Trailer for Two
 > Travel Trailer for Two
Desert Captain
Payson
Posted: 09/03/23 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Dat's da fact Jack!
[emoticon]
* This post was edited 09/04/23 08:22am by an administrator/moderator *
onecb
Salt Lake City Utah
Posted: 09/03/23 09:44am Link  |  Quote  |  Print  |  Notify Moderator
I came back to say thank you for all of the sugestions it gives us a lot to look at. We had not thought of most of these. Alvin
2007 Surf Side 29A Pressurepro tire pressure monitor System
valhalla360
No paticular place.
Posted: 09/03/23 10:53am Link  |  Quote  |  Print  |  Notify Moderator
ktmrfs wrote:
And Tow vehicle mfg generally assume max tongue weight of 10% while trailer mfg design for around 15% min tongue weight. See the problem?
Truck manufacturers are usually spec'ing based on a flat bed utility trailer with negligible wind resistance in addition to the marginal hitch percentage.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
nomadictxn
Pueblo, CO
Posted: 09/03/23 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Desert Captain wrote:
bgum wrote:
Airstream 25FB and 23FB
If price is a problem you may be able to find a lightly used unit.
Airstreams are nice, no doubt but they tend to be heavy. The OP will want to keep trailer GVWR below 5,000# if using a Colorado. My buddy pulled a nice Lance that was 5,000# with his Colorado and it worked fine but anything heavier probably would have had issues.
Good luck.
[emoticon]
I just bought my trailer from a couple that full timed for two years and towed with a Duramax Colorado. This trailer weighs 4200 lbs ready to camp with 520 lbs. tongue weight. They said their set up worked great with an equalizer hitch. I agree with the Freedom Express suggestion on a suitable floor plan. Good Luck!
nomadictxn
2013 RAM 1500 QC 5.7, 3.92 4x4 6 sp.
2021 Flagstaff E Pro 19FBS
BackOfThePack
Fort Worth
Posted: 09/09/23 03:25am Link  |  Quote  |  Print  |  Notify Moderator
Correct. It’s not the weight, per se, it’s aero resistance to crosswinds that are the bane of trailer towing. Tongue weight at 12-13% is an ideal (it’s not “payload”), as 15 is harder to do, and 10 is a little light. WDH percentages are what matter in this.
A pickup isn’t an ideal TV anyway. What is it one carries that MUST go in the bed? An SUV or van is a better choice for DD as well as for being a TV due to greater inherent stability (suspension & COG) than a pickup.
A low COG TV AND TT is the better rig. Give both independent suspension (Airstream, for low crosswind trouble ) and it’s a slam dunk.
“Best” is otherwise non wet-bath and permanent beds (no fold out). 26-28’ TT “generally”.
Much depends on trip length. The longer & farther, the more the above plays in (as does freshwater & propane capacity). As third generation I wouldn’t consider shorter as a full timer rig.
Low cost of travel (daily) is from a clean sheet of paper for rig spec. My 62’ combined length 17k-lb rig averages 15-mpg in the South Central US. (Plan the trip via all stops; fuel cost savings are in the daily driver miles per annual fuel budget). What’s between the ears is what matters most.
10-15 year old AS is what I’d look at. Depreciation gone but still close to new. I bought both vehicles used more than ten years ago, and had just under $30k total into both (knew what to look for). Some DIY upgrade, and ongoing maintenance otherwise. Repairs minimal.
An all-aluminum fill-aero trailer always has a buyer. Or that children & grandchildren can inherit.
* This post was edited 09/09/23 03:39am by BackOfThePack *
2004 555 CTD QC LB NV-5600
1990 35’ Silver Streak
dave54
Northeast CA.
Posted: 09/16/23 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Smaller rigs are easier to tow, but how long do you camp?
Do you take extended trips in winter?
Cooped up in a small trailer during a week long storm is rough on a relationship. Even in our 30' I have been known to don the raingear and take a walk in a downpour just to 'get away' for a while. DW is the light of my life, but 24/7 in a small space...
So many campsites, so little time...
Vintage465
Prunedale CA.
Posted: 09/20/23 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Outdoors RV Manufacturing has a pretty good assortment of coaches that have recliners and TV's in the same viscinity. The walk in shower could be a problem though.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
