RV.Net Open Roads Forum: Need Help Playing Apple Music in My RV
 > Need Help Playing Apple Music in My RV
MaggieChan
Posted: 09/05/23 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys, I recently encountered a bit of a hiccup while trying to enjoy my Apple Music collection on a road trip in my RV.
I have an extensive library of music on Apple Music, and I usually listen to it on my iPhone. However, when I connect my phone to the RV's audio system via Bluetooth, I can't seem to get my Apple Music songs to play.
I've tried to check the Bluetooth Connection. I made sure my phone is properly connected to the RV's Bluetooth system. Calls and other audio sources work fine, so the connection seems solid. I've also checked the settings within the Apple Music app to make sure it's allowed to play over Bluetooth. Just to rule out any issues with my phone, I attempted to connect my iPad and another smartphone, but I faced the same problem. My friend told me to use DumpMeida Spotify Music Converter to download songs and connect them to my RV directly so that I could listen to songs offline in an easy way. Has anyone else had a similar experience or any tips on how to troubleshoot this? I really want to enjoy my favorite tunes while on the road.
If there's a specific setting I might be overlooking or if there's a workaround you've discovered, please let me know. I'd greatly appreciate any advice or insights you can provide.
Thanks in advance for your help and safe travels to you all! ????
TechWriter
Part-Timing Again
Posted: 09/06/23 12:08am Link  |  Quote  |  Print  |  Notify Moderator
In my car I use my stereo's AUX function and connect my iPhone via it's bottom power plug with a 3 mm adapter.
In our RV, the stereo has a USB port which connects via my iPhone's bottom plug.
Last resort is Bluetooth.
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
Boomerweps
Hills of PA
Posted: 09/09/23 07:47am Link  |  Quote  |  Print  |  Notify Moderator
I dumped all my CDs onto a thumb drive that resides in the RV, another copy in my truck.
A hard connection is best. Get an adapter cable.
Most often I have lousy phone reception if any so I can only use downloaded music while camping.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
opnspaces
San Diego Ca
Posted: 09/09/23 07:54am Link  |  Quote  |  Print  |  Notify Moderator
look in
Settings
Privacy & Security
Media & Apple Music
Is there something listed in there that needs permission granted?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
dedmiston
Coast to Coast
Administrator
Posted: 09/09/23 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Is it only a problem through that one app? Can you hear the audio through other apps like Spotify or YouTube? I’m not suggesting you switch apps, just suggesting a troubleshooting tip to isolate the problem.
And there’s nothing wrong with Bluetooth. I disagree with the previous two comments saying hard-wired is the best. Bluetooth is a fine solution.
One more thought… Did this ever work before and quit working now? And does this phone play ok in other vehicles? And do you have a partner who could try their phone as a test?
I would try un-pairing the phone and then re-pairing.
Also, some vehicles treat phone connections differently that music. Take a look at the manual for the stereo.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
nickthehunter
Midwest
Posted: 09/09/23 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Deleted
