LarryDel
Lewes, Delaware
We have a 21 ft TT barely used. We prepared our truck and TT for long awaited trip out west. When we arrived at South Dakota we noticed three tires still looked new but the fourth looks like it has 50K miled on it. It shows a lot of wear. We are very concerned but have no answers as to what it could be. Would appreciate any ideas. Thank you. Larry
CapriRacer
Somewhere in the US
You've got an alignment problem.
Run a string across both tires at the axle level. Compare both sides.
I'll bet the tire wearing quickly is not parallel to the others. That probably means the axle is bent.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Bent axle or bent spindle/mount.
If it’s as bad as you claim, you can see visually which way it’s tweaked.
klutchdust
Orange, California
Jack it up and see if the wheel bearing is loose. Any recent servicing of the axles, new brakes or whatever? Look underneath and check if maybe the spring centering bolt broke. Do both sides look the same?
rub or strike a curb recently? Measure from a stationary point underneath to the center of the hub on each side. Same?
Measure center to center on each hub. Are the axles spaced the same?
TXiceman
Bryan, TX
Out of alignment or a loose wheel bearing.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
JIMNLIN
Oklahoma
It could be one, or more than one, of several issues.
Your on the road so drop by a truck tire dealer with the camper. I've found they know more about tire wear issues on trailers than a rv dealer or car tire dealer down on the corner.
If its just a bad tire or loose bearing or loose wheel lugs... they can fix those issue.
If a bent axle a big rig trailer repair shop can bend the axle back to specs quickly and get you on your way.
mosseater
Dillsburg, PA
Dont rule out spring hangers. Mine needed repositioned from new for the same
reason. Thats the frame work of your axle location. If thats off nothing else matters until spacing is correct.
Sunset Creek 298 BH
TXiceman
Bryan, TX
A year ago, a couple in the park with a brand-new Solitude had bad tore wear from the trip to the dealer in Houston and 40 miles then to their site. After a trip to the dealer to check things and a new tire, they took a 300 mile trip and just about wore out the tire again. Back to the dealer and they had a trailer alignment shop check the trailer and the spring hangers on one axle were not put on right from Lippert.
A trailer shop repaired the spring hangers and Lippert paid the bill and another new tire.
Ken
edited 09/09/23 05:16pm by an administrator/moderator *
TravelingDreamer
Cleveland, OH
All great info above, but start with the easiest. Check tire for out of round. Tire could have been manufactured poorly. Easy to check. Just jack up and spin tire. It should look perfectly round from front and side.
time2roll
LarryDel wrote: We have a 21 ft TT barely used. We prepared our truck and TT for long awaited trip out west. When we arrived at South Dakota we noticed three tires still looked new but the fourth looks like it has 50K miled on it. It shows a lot of wear. We are very concerned but have no answers as to what it could be. Would appreciate any ideas. Thank you. Larry 50,000 miles of wear flat across the tread?
How about post a picture.
http://photoposting.is-great.net/?i=3
675w Solar pictures back up
