Boomerweps
Hills of PA
Garry&Gayle wrote: It is because you set to AUTO it' looking for gas also, set it to AC only.
There is no “AC” button, just auto/gas and on/off
I get the check indicator every time I plug the TT into shore power. If I select the off then on, check goes out.
I don’t normally leave the propane on, especially while traveling. I’ve never traveled over 5 hours away so the refrigerator is just an ice cooler for the trip.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
Garry&Gayle
Hemet, Ca.
Boomerweps wrote: Garry&Gayle wrote: It is because you set to AUTO it' looking for gas also, set it to AC only.
If you press mode button and watch the light it will go to 3 positions left is AC middle is AUTO and right is Gas. My Dometic does this.
Garry&Gayle
Hemet, Ca.
Did you check the fuse on the circuit board on the back of reefer?
