CA Traveler
The Western States
And buy a household tester $10 and check every plug when he's done.
True story: When I was doing the PDI for our current rig which was 2 years old the household tester showed a open ground on all of the kitchen slide outlets. The problem was a open ground in a junction box Monaco mfg did not connect. Prior owner wasn't aware.
2014 Grand Cherokee Overland
Bob
DKLilly67
California
I promise we will definitely reinstall gfci as soon as we figure out where the issue is. Everything we looked at up until that moment lead us to believe the gfci were old and probably needed replacing- and possibly could have led to the problem. The reason we believe the new gfci s were of no help is because before we installed them we had 118 - then after they were installed ( incorrectly) there was 118 at one pole and 2 on the other. When I read the literature that came with the gfci it said to use the yellow sticker and had big warnings everywhere that said if it was hooked up in the wrong way that it would create a hard lockout. There was no way to even remove it, reset it, reinstall it correctly- they were just toast. So we moved on and figured okay we will just take it to basics. That’s when we just put regular receptacles in . We installed both the replacement receptacles as instructed. They read 118 volts, but nothing works when plugged in. We are going to try the unplug from shore power, reset breaker , reset everything right now including inverter.
DKLilly67
California
Okay- good morning to all- please keep sending your thoughts and instructions we will try everything you want us too!
So update- we ran the generator last night ( huge onan in its own huge compartment where most engines go, right under our front windshield) that made it possible for us to have lights, start engine and one plug at kitchen table that works. Fridge is running on propane. We shut everything down last night and went to bed, but by 3:21 am the light under the tv was out so back to generator on - and we thought that way we would at least be able to get to the same spot we were at yesterday before bed. We have now been running generator for about 20 minutes and we can see the charge in the batteries going up, but it still not enough to start engine, let alone turn anything else on. Still no power elsewhere. That’s where we are at. I do have a repair scheduled for later - but I still really believe I’m just missing some step.
way2roll
Wilmington NC
If I were to guess I think you have a battery problem more than an electrical one. Your lights should all be 12V as are the thermostats for your HVAC and potentially your fridge. For some reason even hooked up to shore power your batts aren't charging. Maybe they are completely toast.
2023 FR Sunseeker 2400B MBS
CA Traveler
The Western States
For a discharged battery 20 min is just the start. It can take hours to get to 85% charged. Get the problem fixed, verify that everything is working and the charger is charging the batteries on shore power. When the batteries are fully charged it would be a good idea to load check them to determine their condition.
An alternate is to buy a auto charger to tide you over on batteries, but won't help with the AC problem.
Racklefratz
Anywhere
DKLilly67 wrote: We have now been running generator for about 20 minutes and we can see the charge in the batteries going up, but it still not enough to start engine, let alone turn anything else on.
I'll jump in here, with the caveat that there's still not enough info to make a definitive diagnosis of what's going on. My experience comes from owning and operating Class A RVs 28 years. I'll concede I find it curious that you're the one who's having to try to address these problems.
"and we can see the charge in the batteries going up" - WHICH batteries? House or starting batteries?
Your RV has two mutually-exclusive electrical systems. It has an engine starting system, and a house battery system and each depends on its own separate charging system.
What that means is, your could have lights, etc, that depend on your house batteries to work, and still not be able to start your engine, if the starting batteries are discharged.
The usual way starting batteries are recharged is through the alternator that operates when your engine is running. The converter that normally recharges your house batteries usually won't recharge your starting batteries. System design varies by manufacturer.
Our present Class A has a 12v trickle charger which keeps the starting batteries topped off when our RV is connected to shore power. Yours may, or it may not. If your engine starting batteries are discharged, and shore power doesn't recharge them, you may need to use an external charger to get your engine started.
IMPORTANT NOTE: All the above are variables, which may or may not apply to your RV, due to variations among brands.
With no more information, it's impossible to give any further advice.
last
edited 09/11/23 06:01pm by Racklefratz *
View edit history
DKLilly67
California
Hey everyone!
Doris is alive and kicking!!
We found the problem and got it fixed - hopefully I won’t get this wrong- the distribution J box had a meltdown - there was a short and it actually melted old wiring together. Brand new everything - I have the melted mess in my hand. We are so so lucky. It could have been way worse. I’m grateful for everyone’s help and advice here. We have had our first real life lesson in knowing as much about your RV as you can and always be willing to learn. Many thanks to everyone who contributed and taught us so much!!
You all are the salt of the earth!!!!
CA Traveler
The Western States
So glad for all of you. But please note that running 2 A/Cs on 30A can be questionable. Why? The NEC recommends a max of 80% to limit the heat or 24A for sustained operation and 2 AC's are sustained operation. And your family member issue likely contributed. But your dedication is fantastic and I admire you guys! Thanks for sharing.
Rick Jay
Greater Springfield area, MA
DKLilly67,
Glad to hear all is well. Kudos to you for your persistence and for posting your solution. There have been many posters who never post the solution and that just leaves everyone hanging, without us being able to learn of the problem. Posting your solution can potentially be helpful for others in the future who have similar issues.
I would recommend that if there are any other screws on junction boxes or breaker panels, that at some time someone go around and make sure they're all tight. This includes ground wires for the DC side of things as well. It's possible that the screws can loosen up over time, even on house wiring. In an RV that's bouncing down the road, it's even more likely for the fasteners to loosen with age. A loose connection will generate heat and ultimately create electrical problems.
Again, thanks for following up with your post! ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
DKLilly67
California
Thanks Rick ! We will do that before we leave. I will add it to my growing list of items to check periodically. I really appreciate the tip. I will be following all of you guys to learn more as we go!
