opnspaces
San Diego Ca
Maybe dump the tank and look down the toilet before you add any water. Can you see the bottom of the tank or is there a buildup?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
TexanSon
Bandera, TX
schlep1967: Thanks for the video. I'd heard of both of these products, but didn't have any real reference for how well they worked. I'll look into these.
Thanks, everybody for the info.
TexanSon
USA (Ret.)
TexanSon
Bandera, TX
I don't think my tank is a straight drop tank, opnspaces. But, no, I haven't seen any build up directly below the toilet.
Oregun
Oregon
You could buy/rent a flexible inspection camera and put in the tank through the flush valve in the toilet with the water turned off and take a look inside the tank to see what you are dealing with. Also look for crud buildup on the sensors in the tank level indicators.
valhalla360
No paticular place.
Check out YouTube...the ice trick doesn't do anything.
If on a full hookup site try leaving the valve open with a hose running down the toilet for an hour or so....just keep an eye on it in case something large breaks free and clogs the outlet.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
mosseater
Dillsburg, PA
If there is liquid just below the flush ball looking down into the toilet, at least you know it's full. Do not trust the lights. They are almost universally wrong. Turn the pump off, open the flush valve and see what you can see first.
Sunset Creek 298 BH
rhagfo
Portland, OR
schlep1967 wrote: Go watch this video National RV Training academy. I would go with the liquify brand based on his test.
In your situation it may take a few treatments to get it cleaned out.
I was in your situation, but not full time used about 1/2 box of Rid-x added about 10 gallons of warm water and let it sit for a month.
In your case I would use a heavy dose of either of the two products listed. Go as long as you can before dumping, the use a wand to help clear out the residues.
midnightsadie
ohio
never trust the sensor there wrong from new not a good way to check your problem. pull the commode and get a good light . might pay to pull the tank and clean.
msmith1.wa
Tacoma, WA
Typically there are three sensors on the holding tanks.They are typically spaced at 1/4, 1/2, and 3/4 of the height/depth of the tank. Monitor panels are typically labeled 1/3, 2/3, and full. With this setup when the monitor panel shows full the tank is actually 3/4 full. Or leaving 1/4 of the capacity remaining.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
Bionic Man
Echoing the chorus of don’t trust the sensors. They are never accurate.
When I had the pyramid of poo I used rid-x.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
