RV.Net Open Roads Forum: Fifth-Wheels: 50 amp to 30 amp dogbone
 > 50 amp to 30 amp dogbone
doughere
Mooresville NC
Posted: 09/13/23 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Just purchased a small 5th wheel with a 50 amp service. I have no need for the 50 power, and would like to just connect to a 30 amp cable. Does anyone make a 50 amp female connector to the trailer with 30 amp male end.
CA Traveler
The Western States
Posted: 09/13/23 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Options: 30/50 pigtail adapter widely available.
Put a 50A female plug on a 30A cord. Lighest weight option.
Put a 30A male plug on the 50A cord.
In all 3 cases the 2 hot 50A wires are connected to the 30A hot wire.
2014 Grand Cherokee Overland
Bob
time2roll
Posted: 09/13/23 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
Does the trailer have a detachable cord? Can get a 30 amp to replace it like this: https://www.amazon.com/Conntek-14435-Power-30-Amp-Locking/dp/B00269HEKM?th=1
Otherwise Amazon adapter: https://www.amazon.com/Kohree-Adapter-Dogbone-Electrical-Handle/dp/B07G58NSDK
Shop around
* This post was edited 09/13/23 04:15pm by time2roll *
675w Solar pictures back up
jffnkrn
peoria
Posted: 09/13/23 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
i did the same thing. we only have one a/c so the need to have the 50 amp all the time isn't necessary. Exception; we have tripped the main breaker at the park post when running a/c and water heater. of course just turn the water heater off.
we also have a transfer switch installed and use a Honda EU3000IS generator. Haven't had an issue other than the need to isolate a/c when turning it on.
as far as the cord, Yeah, Amazon is a good place to check and sure beats hauling the large 50 amp cord all over the country.
BB_TX
McKinney, Texas
Posted: 09/13/23 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
The 30 amp power cord with a 50 amp female and 30 male is the way to go. Much lighter and much easier to handle in cold weather. We carried both and normally used our 50 amp cable, but used the 30 amp cable if park only had 30 amp service.
Durb
NW
Posted: 09/13/23 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Progressive Industries electrical management box which hangs down from the pedestal and is kind of heavy (probably because I have a security chain on it too). I find the 30 amp pedestal receptacles are generally worn and the 3 wire connectors allow the EMS box to fall off. I use a 50 to 30 dogbone which stays securely in the pedestal. I have a 30 amp main disconnect in the trailer so I am not overloading my 30 amp power cord.
I believe carrying the adapter to be almost mandatory.
StirCrazy
Kamloops, BC, Canada
Posted: 09/14/23 07:48am Link  |  Quote  |  Print  |  Notify Moderator
just get the 50amp to 30amp adapter, don't modify anything and risk doing it wrong or lowering the resale value later.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
laknox
Arizona
Posted: 09/14/23 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
When I had a 30a FW, I got a 50 to 30 dogbone so I could use the 50a plug at campgrounds. They were generally tighter and much less prone to tripping. My current FW is 50a but only had 1 A/C until a couple months ago. I =always= use the 50a plug unless there is't one available. Dogbones are the way to go; don't take up much room and a lot cheaper and easier than futzing about with changing plug ends or buying new cords.
Lyle
* This post was edited 09/14/23 04:04pm by laknox *
2022 GMC Sierra 3500 HD Denali Crew Cab 4x4 Duramax
B&W OEM Companion & Gooseneck Kit
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
