RV.Net Open Roads Forum: Tech Issues: Propane Refills
 > Propane Refills
LMHS
NM
Posted: 09/16/23 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
I pay by the gallon. I rarely have a completely empty tank to fill. The company that fills my 20# tanks will weigh them and fill them by the metered gallon. More than once I have had 3 tanks filled and they have all been on the same ticket (NM law prohibit transporting more than 3 LP tanks in a passenger vehicle at one time).
My choice of where to fill is dictated by the fact that I know the steps taken to correctly fill a tank. I've walked away from a fill station, with my empty tank, when a step is skipped.
I carry two 20# tank on the truck camper that I refill. One is "mine" (painted light turquoise) and the other is painted white. The white one is my "swap" tank. I always carry a tank dedicated for swapping. As that tank nears it's exp date, I replace it. I do not replace my other tanks. I take very good care of my tanks. They are rust free, dent free and clean. I repaint them every few years as they get skint up from use. When I refill, the tanks are inspected, particularly the foot ring, before refilling.
The people who fill my little tanks work for and are trained by the same company who fills my big horizontal tank.
You have to be careful when swapping tanks. More than once I have gotten an out of date/recertified tank. My last 4 tanks, I ended up buying new. It was just easier to do it that way. It has gotten hard to get a newish tank from the swaps in my area. I have rejected several "swaps" due to condition too.
CA Traveler
The Western States
Posted: 09/16/23 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
LMHS Why are your tanks weighed? When "your" tanks are out of date do you have them recertified? And are you concerned about the foot ring becoming loose? Just curious.
2014 Grand Cherokee Overland
Bob
ktmrfs
Portland, Oregon
Posted: 09/16/23 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
around here I can buy a 5 gallon tank with a real float gauge at costco (usually in the spring) for less than the cost to recertify a 5 gallon tank.
7.5 gallon tanks, or 1 gallon tanks, another story recert is way less expensive than a new tank.
My opinion is that the 5 gallon tanks are a "loss leader" at stores.
2011 Keystone Outback 295RE
StirCrazy
Kamloops, BC, Canada
Posted: 09/17/23 08:31am Link  |  Quote  |  Print  |  Notify Moderator
joebedford wrote:
I usually get 20lbs in a 20lb cylinder (by weight). Not 20lbs less 20%.
are you filling an old tank with the old-style valve? If not, there is no way to get that much in it unless the place filling it is breaking the law. in a 20lbs cylinder, which are the same size they have always been, with the new valves and regulations they can only hold 16lbs or 3.89 gal. if a place is telling you they put 20lbs in or charges you for that, they are ripping you off or breaking the law filling the cylinders.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
StirCrazy
Posted: 09/17/23 08:37am Link  |  Quote  |  Print  |  Notify Moderator
It costs more to recertify up here than to buy a new one at Costco filled. It's 70 bucks just to retest and certify a 5 to 40lbs vertical tank here, where for 40-50 bucks normally, I can get a new 30lbs from Costco filled.
ktmrfs
Portland, Oregon
Posted: 09/17/23 09:26am Link  |  Quote  |  Print  |  Notify Moderator
My experience as well on 20lb tanks. And the Costco ones I get have a float based level gauge that is pretty accurate.
CA Traveler
The Western States
Posted: 09/17/23 09:43am Link  |  Quote  |  Print  |  Notify Moderator
The Costco 20lb tanks are $50 in the Phoenix area, empty of course.
ktmrfs
Portland, Oregon
Posted: 09/17/23 09:59am Link  |  Quote  |  Print  |  Notify Moderator
I paid $29 last spring for 5 gallon tanks with a level gauge at Costco.
Here costco usually only has them in the spring.
Empty, but to recert the tank must also be empty.
Dutch_12078
Winters south, summers north
Posted: 09/17/23 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
I'm a certified LP refiller and trainer. I've been filling LP tanks of various sizes for over 40 years.
My 20 LP cylinders when filled by opening the "spitter" (Fixed Liquid Level Gauge) until liquid flows weigh out at 20 lbs plus TW. My 30 lb cylinders at 30 lbs plus TW, and my 40 lb cylinder at 40 lbs plus TW. The 16 lbs you claim is incorrect. The LP capacity is 80% of the total water capacity of the cylinder, not 80% of the rated LP weight. A 20 lb rated cylinder holds 4.6 gallons of LP. A 30 lb rated cylinder holds 7 gallons of LP, and a 40 lb cylinder holds 9.4 gallons of LP. Actual total weights are a function of the LP weight plus the cylinder Tare Weight and minor variations due to ambient temperature differences.
Dutch
2001 GBM Landau 34' Class A
StirCrazy
Posted: 09/18/23 09:42am Link  |  Quote  |  Print  |  Notify Moderator
There are some differences that density brings in. so,, while you can only fill to 80% of the capacity, due to the density, it in reality it is somewhere in between depending on the temperature. I was keeping it simple. so volume wise you can fill it to about 3.89 gal which is 16lbs but temprature if it is cold could make it weight more as the density is increased so you get a bit more propane in the same volume. it's the same as gas for your car, all volumes are calibrated at a specific temp. I remember the days we used to be able to fill to 100% and the tanks used to run the BBQ quite a bit linger haha.
 > Propane Refills
