RV.Net Open Roads Forum: Beginning RVing: How to reconnect awning lever?
 > How to reconnect awning lever?
SCADAMAN29325
Clinton, SC
Posted: 09/15/23 08:10am Link  |  Quote  |  Print  |  Notify Moderator
The latch lever is not in the loop. It's been this way since we've had it and just use the long strap rod to push it up to unroll. How can I fix this WITHOUT disassembling the awning arm?
THANKS!
THANKS! Phil and LuAnn
1st timers, brought it home 2022-10-19.
1994 Fleetwood Jamboree Rallye
M-T31-Ford-460, 1994 Ford E350
I may not know what I am doing, but I am having fun doing it!
opnspaces
San Diego Ca
Posted: 09/15/23 09:36am Link  |  Quote  |  Print  |  Notify Moderator
The strap with the loop on the end should have some side to side flex it in. Maybe try rolling the awning up slightly until the pin is as far away from the loop as possible. Then slide the loop up and see if it can flex over the pin.
* This post was edited 09/15/23 02:01pm by opnspaces *
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
