RV.Net Open Roads Forum: Lance travel trailer slide out stops half way
 > Lance travel trailer slide out stops half way
vicmitch
Cloquet MN
Posted: 09/15/23 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Thru the course of summer camping on 3 occasions, the slide out on our Lance travel trailer stopped half way in, with the. ‘In’ switch still pressed, backed it back out a little each time and retried the ‘in’ switch, then the slide out came in the rest of the way, no problem. Camper is always sitting level with the support jacks down. Even though it corrected itself each time, it makes one a little nervous.
CA Traveler
The Western States
Posted: 09/15/23 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Have you lubed the mechanism recently? Are the batteries fully charged when this happens? Load check the batteries.
2014 Grand Cherokee Overland
Bob
vicmitch
Cloquet MN
Posted: 09/16/23 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Camper was plugged into electrical power each time, so the voltage should have been good but I will have the batteries checked out, slide out manual says it is designed to be maintenance free except for the preservative treatment for the seals.
Y-Guy
Tri-Cities, WA
Posted: 09/16/23 08:53am Link  |  Quote  |  Print  |  Notify Moderator
For what it's worth with my previous TT's and 5er (as well as our motorhome) we've always been told to keep the trailer plugged in to the truck with the engine running when extending or retracting the slides. I could notice the difference in how well the slides performed when I did that.
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
klutchdust
Orange, California
Posted: 09/16/23 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Class c bedroom slide did the same thing. The slides were dirty and the strain on the motor shut off the motor on the internal protector.
I would have to pull off the mattress and undo the plywood platform.
Cleaned and lubed the slides and it worked well. I used a dry lube.
Anything oily will only attract more dirt. I found an access hole for wiring was not sealed properly, it allowed dust to come in. As We desert camp and dirt roads are common it was a problem.
The salesman said the slides were maintenance free, [emoticon] with a straight face?
