RV.Net Open Roads Forum: Tech Issues: Replace television
 > Replace television
Salty Dog
Upstate NY
Posted: 09/16/23 10:28am Link  |  Quote  |  Print  |  Notify Moderator
When traveling north on the Alaska Highway, a mounting bolt broke and destroyed the rear cover of our TV. This part is not available for replacement. Now that we are headed back to the lower 48, I am looking to replace it. What concerns should I have regarding a replacement TV? Our rig is a 2021 Montana 3791RD and had the original 50" TV - 120V. Thanks in advance!
Wife, kids, somebody else's kids, dog, kitchen sink
Cleverly disguised as an adult.
Thermoguy
Graham, WA
Posted: 09/16/23 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
I think you only need to make sure if fits in the space you need. I have a 43" Samsung 4K TV that has been great. It sits in a cabinet (older trailer) and I don't secure it in any way, the legs on the TV hold it just fine.
QCMan
Independent Republic of Horry
Posted: 09/16/23 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
If you stick with the same size it will be fine. If it wasn't a smart tv it is time to get one. I would not get one that needs a particular service to use. Others will tell you which they are. Vizio seems to hold up well in travel trailers so a 5er should be easy for it. Newer flat screens seem to be lighter than they were. Just replaced a 55 with a 65 and it weighed 11 pounds more with the base and both weigh the same without bases.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
Posted: 09/16/23 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
First you say it destroyed the rear cover... Question does the set still work.. If so I'd just patch the rear cover. Glue someting to it to protect the innards or use somethign like eternabond or gorallia tape.. (NOTe if usign eternabond put somethign over the hole for it to stick to like a piece of paper then put the eterna bond over that overlapign by a half inch or so.. That is a very "Super" Tape and serious over kill)
Otherwise your primary concern is "Will it fit"
IN my RV I took out an old boat anchor CRT and put in anew wide flat screen. I measured carefully and the width was.. IDENTICAL.. it was not as tall however so I did a bit of cabnetrey to make the opening smaller... Looked good when I was done.. Added some storage under it as well. Wanted to add behind but never got the old round tuit.
CA Traveler
The Western States
Posted: 09/16/23 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Good point. I repaired a plastic A/C cover with fiberglass, some sanding and spray paint. Yo u can't tell that a Cottonwood tree branch fell on it.
2014 Grand Cherokee Overland
Bob
wildtoad
Blythewood, SC
Posted: 09/16/23 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
My experience with Vizio is they are good but may have minimal features such as audio adjustments. Go where you can see them and go through the menu systems.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Posted: 09/17/23 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Oh one item of interest
Some campgrounds offere cable TV
BY Federal law all TV's sold in the US must offer ATSC (American Television Standard Comittee) Digital decoders (This is broadcast TV standard) most, if not all, also decode NTSC (National Television Standards Comittee) The old analog standard.
QAM however (Quadrature Amplitude Modulation) (Digital cable) decoders are NOT reuired by law (NOTE Decoder may also be called Demodulator)
Last I knew ELEMENT did not include QAM. in their tuners... Most others do.
I just got one at a pawn shop that was the right size.. Very happy.
Another consideration is inputs.. The TV I'm using now has one HDMI one Standard 3-lead (Composite) one Computer and one Antenna (RF) in.
The one I got at the pawn shop had I think two 3-lead and 3 HDMI in addition to the VGA computer nand A RGB ...
