RV.Net Open Roads Forum: Tech Issues: DEF fluid
 > DEF fluid
Mayor30
Pa
Posted: 09/16/23 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Is all DEF fluid the same? I usually buy the Blue DEF but it's now about $20. Our local hardware store has the Blue DEF and another one that is $12.99. I did buy the Blue DEF but just wondered if the cheaper one would be ok.
KD4UPL
Swoope, VA
Posted: 09/16/23 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
It's cheaper to buy it from a pump at a fuel facility. I get mine from the pump at Quarles for around $4 something a gallon.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 09/16/23 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Or buy the Walmart Brand for $9 to $12 for 2 1/2 Gal. Been using it since 2005 in three different trucks and no issues.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
ktmrfs
Portland, Oregon
Posted: 09/16/23 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
DEF is regulated to be a specific formulation so they are basically all the same.
Recently Costco had blue def for $12 for 2.5 gallons. I just buy from places that likely have decent turnover of the fluid so it hasn't been sitting on a shelf for months and months.
2011 Keystone Outback 295RE
Bionic Man
Posted: 09/16/23 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
DEF is DEF. I don't spend more for the Blue. I either get it from Walmart, or from the pumps at a truck stop (I like Maverick).
If you buy it at Walmart (or anywhere) I'd look for the expiration label. From what I have read, expired DEF won't hurt your engine, but you will use more.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
ppine
Northern Nevada
Posted: 09/17/23 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Very simple formula. No perceived difference between suppliers of DEF.
Posted: 09/17/23 10:34am Link  |  Quote  |  Print  |  Notify Moderator
2005? Mmmmkay
Thermoguy
Graham, WA
Posted: 09/17/23 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
Some stores offer a premium DEF - Platinum I think... You don't need that. Just buy the regular Blue DEF. Last time I had to look around for the cheaper stuff.
Thermoguy
Graham, WA
Grit dog wrote:
2005? Mmmmkay
I'm guessing he means 2015...
Vintage465
Prunedale CA.
Posted: 09/18/23 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Tractor Supply and Walmart seem to have the best prices, even for name brands
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
 > DEF fluid
