tourusa
Ft Lauderdale
Thanks yes this is what I’ve been doing from your post to unlock then put in position and re-lock in place I’m wondering if there is play between where it locks around the frame during transit or if I should leave it unlocked, have a ticket open with lippert also
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
opnspaces
San Diego Ca
The damage is bent inward from outside the coach and into the interior. That means something on the steps is hitting the frame and then pushing inwards when closing.
All you have to do is step inside the coach and have somebody else lift the steps up while you watch to see what is hitting and bending it. then make sure in the future you don't do whatever it was that you were doing to cause the impact.
the other possibility is after the steps are up and locked the closing door hits the steps and pushes them further into the coach and bends the frame. But if that was the case, I would think there would be marks on the inside of the door where it contacts the steps.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
laknox
Arizona
One more reason to ditch the stupid solid steps...
Check out the Torklift Uprising folding steps that replace the stuipd solid steps. I have the Glowstep Revolution under mount, and love 'em. I can only imagine that the Uprising steps are along the same quality.
Lyle
2022 GMC Sierra 3500 HD Denali Crew Cab 4x4 Duramax
B&W OEM Companion & Gooseneck Kit
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
