Kountryguy
Emery,SD
Looking for suggestions for the easiest way to upgrade the receptacles in my trailer.
QCMan
Independent Republic of Horry
I don't know if there is anything easier than replacing them with residential units. If you have room behind, use shallow old work boxes to put them in.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
LouLawrence
Traveling the US fulltime since 2000.
Upgrade to what?
CA Traveler
The Western States
I wondered also. I wanted to say easy to change colors but...
2014 Grand Cherokee Overland
Bob
pianotuna
Regina, SK, Canada
Hi,
The oem stab connectors are pretty much frowned on for use with heavy loads. One of the first things I did was to replace all but 2 of the outlets.
Regards, Don
ScottG
Bothell Wa.
Have you had problems with yours Countryguy?
Tvov
CT
Just poking my nose in here to find out about upgrading outlets.
2021 F150 2.7
Kountryguy
Emery,SD
Yes ScottG. The one on my dryer connection broke. Pianotuna, what did you replace yours with?
pianotuna
Regina, SK, Canada
Kountryguy wrote: Yes ScottG. The one on my dryer connection broke. Pianotuna, what did you replace yours with?
Standard residential screw terminal type.
Blacklane
New Carlisle, Ohio USA
The devices that have the wire wrap around a screw are not appropriate for the vibration environment in an RV. You need to choose ones with screw clamps, often labeled as "commercial". Even back-stab connections are more reliable than wrapped screws in an RV.
People often say that RV self-contained devices are junk, but the ones by the major suppliers are approved by UL and CSA and are perfectly safe. They are specified in the National Electric Code (NEC). They do have to be installed correctly using a special tool.
People used to say that crimp connections were junk, however that is the only kind of connection you will find in a modern automobile because they are the most reliable.
edited 09/19/23 04:59pm by Blacklane *
