RV.Net Open Roads Forum: Tips on how to hook up at an extreme angle?
 > Tips on how to hook up at an extreme angle?
TenOC
On the road -- Full time
Posted: 09/18/23 08:45am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2014 3100RL Montana with Mor/ride RPB72-1116 king pin with a Demco Autoslide 18K 5th wheel hitch.
Last campsite we had to unhook at an 25 to 35 degree angle – the first time for us. When we tried to re-hook we had difficulty connecting the hitch. Any suggestions or tips on how to hook up at an extreme angle?
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
CarnationSailor
Cathedral City, CA
Posted: 09/18/23 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I have the same Demco hitch. Knowing that it will be extremely hard to unhitch/hitch up at an angle greated than 5 degrees, I make sure I never have to do that. This includes not reserving curved pull-thru's.
You could remove the locking plate from your pin box, hitch up, and then TRY to re-install the locking plate; however, I expect it would be very difficut or impossible to re-install the locking plate.
I wish I could be of more help.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
opnspaces
San Diego Ca
Posted: 09/18/23 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Not knowing 5th wheels is the locking plate necessary to move the trailer? Can you hitch up without it and move the trailer to level ground and stop and re-hitch? Yes it's a bunch of extra work. But desperate times call for desperate measures.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
TenOC
Posted: 09/18/23 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
CarnationSailor wrote:
s.
You could remove the locking plate from your pin box,.
To remove the locking plate is a 1/2 to 3/4 hour job.
CarnationSailor
Cathedral City, CA
Posted: 09/18/23 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
s.
Maybe that's another reason why removing and re-installing it isn't a viable solution.
Campinfan
Washtenaw County, Michigan
Posted: 09/19/23 03:50am Link  |  Quote  |  Print  |  Notify Moderator
I have a Demco but there is no locking plate, it has the silver guide rails on the hitch. I have pulled them off or backed them all the way off....was pretty easy.....hooked up and then pulled out. If I had them off. I stopped, put them on and rehitched. Only took a few minutes. Without the rails in place, the hitch still works, it just does not "autoslide". If I had the rails backed off, I just slid them over once the trailer was straight and then tightened them.
My hitch is a few years old now so the design might be a bit different from the new ones.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
GottaRunGottaCamp
East of Atlanta, Ga.
Posted: 09/19/23 04:59am Link  |  Quote  |  Print  |  Notify Moderator
I have a Pullrite 24K Superglide hitch, the owners manual says the maximum angle of the trailer to the truck (being parallel to each other) is 10 degrees either way
2016 F350
2019 Heartland Torque TQ-371
Martyn
Panama City Beach, FL USA
Posted: 09/19/23 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Mine is the same as this ^^. I would do exactly the same given the circumstances. Just a few bolts to loosen off/remove and the hitch acts like a regular hitch and doesn't slide.
The only alternative to this is to have a friendly neighbor hitch up to your trailer and pull to a spot where you can hitch up straight.
2020 Keystone Cougar Half-Ton 27SGS;
2019 Dodge Ram 2500 QC 4x4 6.4 Hemi BigHorn;
DEMCO Autoslide; 2 Honda EU2000i's;
Our Website
Ed9824v
Agua Dulce, Calif. 70 mi N.E. of Los Angeles
Posted: 09/19/23 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Can rails be removed with the pullrite?
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
CarnationSailor
Cathedral City, CA
Posted: 09/19/23 10:22am Link  |  Quote  |  Print  |  Notify Moderator
The problem is with the locking plate, not the rails. If you have a locking plate, then the rails serve no purpose. In fact, I had to permanently remove the rails on mine due to the type of pinbox I had.
