TexanSon
Bandera, TX
I just found out that when the dealer replaced the store power plug, they reversed the white and black wires. Had to replace the plug today, and I discovered this and wired the new plug according to the diagram. It's a 30 amp trailer. Is there anything I should be alert for after this? Any additional steps I should take?
TexanSon
USA (Ret.)
opnspaces
San Diego Ca
You should be fine as far as the miswire. The additional step you should take is buy a $10 tester at Lowes or Home Depot and make sure it is correct.
Tester
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
CA Traveler
The Western States
X2 Check with the tester. There are no wire color standards for a RV. Diagrams and so forth until they don't have that wire or color. Production doesn't stop and wait for a Amazon delivery.
2014 Grand Cherokee Overland
Bob
JRscooby
Indepmo
As campground host in a state park, all I was allowed to do when camper complained about electricity was plug in a tester. Mostly it was "See, the pole is right" but sometimes call maintenance, see how long before repair could be made.
The most common complaint was GFI on camper would trip. I would offer to let camper owner plug my tester into outlet that was not GFI protected. Most times would indicate mis-wiring someplace between pole and outlet.
StirCrazy
Kamloops, BC, Canada
you could have just reversed them where they attached to the power center instead of replacing the plug.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
JRscooby
Indepmo
StirCrazy wrote: you could have just reversed them where they attached to the power center instead of replacing the plug.
I'm not a fan of telling strangers how to do electrical work, but why would you want to have any part of system mis-wired?
Fix it where the mistake was made, don't compound the problem
TexanSon
Bandera, TX
One of the posts burned, melting the plastic and burning out a piece of the black wire, and tripping the main breaker. Pretty sure I needed to replace the plug at that point. The wires coming out of the shore plug cable matched the diagram included with the plug, so I'm assuming that it is wired correctly now, but I don't have a tester, and won't be able to get one for a couple of weeks, at least.
CA Traveler
The Western States
Buy the tester with a GFCI test button and you check GFCIs. Amazon $13.
StirCrazy
TexanSon wrote: One of the posts burned, melting the plastic and burning out a piece of the black wire, and tripping the main breaker. Pretty sure I needed to replace the plug at that point. The wires coming out of the shore plug cable matched the diagram included with the plug, so I'm assuming that it is wired correctly now, but I don't have a tester, and won't be able to get one for a couple of weeks, at least.
ahh see you failed to mention that in your original post, all of which would have been helpfull.
